Old 07-28-2008, 09:01 AM   #1 (permalink)
rjacob's Avatar
2017 Honda Civic LX - '17 Honda Civic LX
90 day: 39.92 mpg (US)
Cruise control mod idea
How about a simple cruise control that holds throttle position, not speed. It would be simpler than a regular cruise control. It would be like a throttle lock, but it would disengage if the brake is pressed. Also the manual control, could bump up or down the throttle position. It can be dumb as a stump. It doesn't need to monitor anything like speed or rpms I don't think. I think it can just hold the cable at the set position, period. Then if you want to bump it up, it pulls the cable just a little more. If you want a little more trottle, you bump it a little more.
Someone could probably modify an junked cruise control.
Seem reasonable?
GreenCarMPG.com
Old 07-28-2008, 10:08 AM   #2 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
the simple old school way is a foot feeder block, a device that you use to hold the throttle where you want it .. basjoos has one in his civic.. Ill be adding one for my crx before our trip this year.. 3000 miles to Texas and back.. hopefully on under 50 gallons of gas
Old 07-28-2008, 04:03 PM   #3 (permalink)
JC Whitney used to offer one way back in the early 80's. A friend installed one on his VW bus. As i recall, it was a real simple mechanical device that attached under the accelerator pedal, to the linkage, and had a cable up on the dash. When you tapped the gas pedal, it disengaged I think.
If you come up with one, let me know, I'd be interested, too.
Old 07-28-2008, 05:15 PM   #4 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
In hilly terrain you'll be going slow up hill then flying down hill! Might work in northern IN and abought all of KS and other flat states
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
Old 07-28-2008, 05:18 PM   #5 (permalink)
A simple hand throttle can be made for this purpose...you use an old fashioned hand operated choke mechanism that consists of a notched lever attached to a cable and mounting system that would hook up to your choke, but in this case you hook it up to the thottle linkage...can be bought at most car parts places.
95 Neon-43 mpg
Old 07-28-2008, 05:53 PM   #6 (permalink)
homeworkhome53's Avatar
Workride - '07 Chevrolet Aveo5 SVE
90 day: 51.74 mpg (US)
I have no traditional CC. I use a threaded rod witha foot piece that captures the gas pedal and a finger which captures the edge of the dash. Turning the threaded rod increases/ decreases the speed. I've been using it for a cuople months without any problems.
homeworkhome53
ID:	1294   Click image for larger version
Old 07-29-2008, 03:39 AM   #7 (permalink)
1997 Civic POS - '97 Honda Civic EX
90 day: 33.29 mpg (US)
Send a message via AIM to ajax_6531 Send a message via Yahoo to ajax_6531
I think you'll find some good info in this thread:http://ecomodder.com/forum/showthrea...trol-2637.html
IYAOYAS
Old 07-29-2008, 04:56 AM   #8 (permalink)
Yes, That has some very good info. My threaded "stick" is the 2nd generations of the one mentioned there.
homeworkhome53
Old 07-29-2008, 06:13 AM   #9 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
I like that threaded stick technique. I'll definitely look into something like that.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-29-2008, 09:25 AM   #10 (permalink)
rjacob's Avatar
No offense, but I was thinking of something a little cleaner, more OEM-like than a stick...
I am guessing the basic guts of a cruise control are probably fairly simple. I wonder if I can pick up a fried one cheap? The motor part would need to work at least.
GreenCarMPG.com
Cruise Control (with MPG sensitive logic) guitarterry EcoModding Central 224 05-13-2017 11:10 PM
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Audiovox CCS-100 cruise control replacement (can't do FE tests) MetroMPG Off-Topic Tech 28 08-15-2009 02:55 PM
Idea: hypermiling cruise control rjacob EcoModding Central 5 04-14-2009 02:17 AM
3 ?'s (SuperMID; cruise control for Metro) Pillzilla EcoModding Central 16 03-31-2008 06:34 AM
