09-06-2013, 09:15 PM
#11 (permalink)
That's a nice project. I've been lurking to get a similar setup into a smaller motorcycle, such as a Yamaha Teneré 250.
09-07-2013, 02:03 AM
#12 (permalink)
As much as I like the diesel conversions on motorbikes, you make me come to the conclusion that it is a lot of involvement / hassle for basically regular 125 cc performance, be it acceleration, FE or top speed and even purchase price.
I have checked on the dieselbike.net forum because I thought there was more potential in dieselizing a bike engine.
The answer is basically no from the narrow minded engineers from automotive and yes for the dreamers.
09-07-2013, 02:52 AM
#13 (permalink)
When the bike is purely being used around town, and is running on fuel that doesnt even touch 50p a liter then im happy with the hasttle.
To be honest, the fuel effeciency should be around 170-180 one its bedded in which is higher than a 125 petrol scooter would get.
The HDT modified KLR 650 is what you want if you want an off the shelf diesel bike.
09-07-2013, 02:53 AM
#14 (permalink)
Thanks! We all use big motorbikes becuase the engine and gearbox combinations are huge, or much larger than the same cc petrol versions.
The smallest bike I would think would work is a CB400/250, as they were big anyway.
09-07-2013, 11:01 AM
#15 (permalink)
Ho, I don't want anything off the shelf, I'm amongst the dreamers !
As for the hassle, keep it up on your excellent project I wish I could handle.
09-18-2013, 03:12 AM
#16 (permalink)
I've already considered to attempt a centrifugal clutch cimilar to the one used in the original Mobylette, since it provides a similar effect to a CVT in a lighter and more compact package, with no gearbox at all.
I like the current Yamaha XTZ250 Teneré available here in Brazil, since it has a comparatively big fuel tank for a compact motorcycle and has some cross-country abilities which I would enjoy.
05-25-2014, 10:24 AM
#17 (permalink)
Cyborg ECU
A search for "diesel motorcycle" on EM yielded this old thread, and I thought I would add this link I just found. A day-dreamer idea is to convert the old Bajaj Chetak scooter I have in the garage. Too many projects and too much to learn! But I can dream. Diesel Motorcycles at DieselBike.net | Listing all Diesel Motorcycle projects
05-25-2014, 07:39 PM
#18 (permalink)
Originally Posted by California98Civic
There are some interesting projects on that site, and even a picture of a Vespa with a single-cylinder Diesel mounted on its floor. Anyway, about 7 years ago I've already considered to work around a 2-stroke gasser to run on Diesel, but since it would probably still require a supercharger for the scavenging I considered it too much more complicated than what II would want to do. At that time I still thought hot-bulb engines were real Diesels
Anyway, in a Vespa or a Bajaj Chetak, apart from the transmission setup, another critical issue to consider while converting to any other engine is the weight balance due to engine position.
05-26-2014, 01:34 AM
#19 (permalink)
Had I time and money, I would try to convert a Suzuki DR 800 (for the long stroke and tough internals) to a smaller bore barrel (like a GN 400), machine a head out of a lump of alloy, stick a Fiat Tdid piston and injector on it.
Main concern was the oppportunity to close up the valve angle and still use a standard bike cam.
Maybe two ?
