Old 09-06-2013, 09:15 PM   #11 (permalink)
That's a nice project. I've been lurking to get a similar setup into a smaller motorcycle, such as a Yamaha Teneré 250.
Old 09-07-2013, 02:03 AM   #12 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
As much as I like the diesel conversions on motorbikes, you make me come to the conclusion that it is a lot of involvement / hassle for basically regular 125 cc performance, be it acceleration, FE or top speed and even purchase price.
I have checked on the dieselbike.net forum because I thought there was more potential in dieselizing a bike engine.
The answer is basically no from the narrow minded engineers from automotive and yes for the dreamers.
Old 09-07-2013, 02:52 AM   #13 (permalink)
When the bike is purely being used around town, and is running on fuel that doesnt even touch 50p a liter then im happy with the hasttle.
To be honest, the fuel effeciency should be around 170-180 one its bedded in which is higher than a 125 petrol scooter would get.
The HDT modified KLR 650 is what you want if you want an off the shelf diesel bike.
Old 09-07-2013, 02:53 AM   #14 (permalink)
Thanks! We all use big motorbikes becuase the engine and gearbox combinations are huge, or much larger than the same cc petrol versions.
The smallest bike I would think would work is a CB400/250, as they were big anyway.
Old 09-07-2013, 11:01 AM   #15 (permalink)
OldContinents
Ho, I don't want anything off the shelf, I'm amongst the dreamers !
As for the hassle, keep it up on your excellent project I wish I could handle.
Old 09-18-2013, 03:12 AM   #16 (permalink)
I've already considered to attempt a centrifugal clutch cimilar to the one used in the original Mobylette, since it provides a similar effect to a CVT in a lighter and more compact package, with no gearbox at all.
I like the current Yamaha XTZ250 Teneré available here in Brazil, since it has a comparatively big fuel tank for a compact motorcycle and has some cross-country abilities which I would enjoy.
Old 05-25-2014, 10:24 AM   #17 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
A search for "diesel motorcycle" on EM yielded this old thread, and I thought I would add this link I just found. A day-dreamer idea is to convert the old Bajaj Chetak scooter I have in the garage. Too many projects and too much to learn! But I can dream. Diesel Motorcycles at DieselBike.net | Listing all Diesel Motorcycle projects
Old 05-25-2014, 07:39 PM   #18 (permalink)
There are some interesting projects on that site, and even a picture of a Vespa with a single-cylinder Diesel mounted on its floor. Anyway, about 7 years ago I've already considered to work around a 2-stroke gasser to run on Diesel, but since it would probably still require a supercharger for the scavenging I considered it too much more complicated than what II would want to do. At that time I still thought hot-bulb engines were real Diesels
Anyway, in a Vespa or a Bajaj Chetak, apart from the transmission setup, another critical issue to consider while converting to any other engine is the weight balance due to engine position.
Old 05-26-2014, 01:34 AM   #19 (permalink)
OldContinents
Had I time and money, I would try to convert a Suzuki DR 800 (for the long stroke and tough internals) to a smaller bore barrel (like a GN 400), machine a head out of a lump of alloy, stick a Fiat Tdid piston and injector on it.
Main concern was the oppportunity to close up the valve angle and still use a standard bike cam.
Maybe two ?
