Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 05-20-2012, 12:49 PM   #31 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
Originally Posted by mcrews View Post
Really, there should be some minimuum test to post. Like how to use puncuation. Everybody is babysitting this guy.....we go uot of our way.....and we get 'shut up'!
Maybe he's texting while driving.....I don't know.
while his typing skills are flawed; your attitude is flawed. understanding where someone is coming from rather then *****ing about them would help.
guess the american system of education strikes one out of the park again, eh?
Old 05-20-2012, 01:49 PM   #32 (permalink)
Originally Posted by ramman360 View Post
No I was getting 12 ish. Put 33s on the truck
So out went down too ten.then the cai got me back to ten.then then the. Superchip tuner to 11. Then my intake blew out so I was down too 5 ish. Now with new 02 sensors and no evap I'm getting 16. And am now done with this site and the people on it.
thanks for quantifying your fe, but as someone else said the improvement from blanking off the evap is probably due to replacing the o2 sensors, unless something was seriously wrong with the evap system before.
Replacing the old blown out intake with a CAI isnt a 5mpg improvement from the CAI- it simply restored the fe lost by the ruined intake to the same level as before.
Nothing personal, its just what you've claimed isn't backed up so I'm not going to try it. Although 16mpg does sound quite reasonable for a truck of that size in city driving.
Old 05-20-2012, 02:11 PM   #33 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Hummmm, not a big fan of dumbing down.
Being oblivious to what everyone else is doing.......
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-20-2012, 02:30 PM   #34 (permalink)
...beats walking...
...some of us are obviously oblivious, others are not-so-obvious about it (ha,ha).
Old 05-20-2012, 02:54 PM   #35 (permalink)
forest from the trees, interesting not a new concept; not too sure you'd know a tree if it hit you.
but best of luck with that.
for the op;
if you do have a check engine light; key on and off 3 or 4 times, it should give you any codes stored
Old 05-20-2012, 05:40 PM   #36 (permalink)
mcrews's Avatar
There has to bee an award, obviously, for that sentence..... I am just oblivious to what it could be.....
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-21-2012, 12:15 AM   #37 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
none cents or nonsence
disconnecting EVAP has zero effect on FE
(except for .... see below)
the ECM will use feedback from the 02 or AFR sensors to keep the
air / fuel ratio at 14.64 to 1 on most cars and where ever it wants it on the rest .
an EVAP system that is functioning as designed can not change this
if you disconnect the EVAP system the system will set a DTC for restricted flow and or incorrect vacuum supply to the LDP leak detection pump , assuming the system has a LDP , some do not .
the DTC will suspend some system testing . the CEL / MIL will remain ON until the system is repaired .
the car will leak HC emissions , which is bad , but wasted HC is wasted fuel that could have been used to move the car down the road so
disconnecting EVAP
ultimately
will UN-improve fuel economy
to the OP...
you need not understand this for it to be true .
the EVAP can function at any time
at the pleasure of the ECM not just at start up
The Following User Says Thank You to mwebb For This Useful Post:
baldlobo (05-21-2012)
Old 05-21-2012, 12:55 AM   #38 (permalink)
thanks mwebb. i was wrong about my info on evap
i have the service manual for my jeep(knowing chrysler it's operation probably doesn't change between cars); anyway i am wrong the evap solenoid doesn't work at start up cold(timer delay for hot) or other wise it only works after reaching closed-loop, after that 5-10 per second.
Old 05-21-2012, 08:35 AM   #39 (permalink)
I wish people would read. A I have a touch screen smartphone. Second if you have a question call me cause its quicker if you can be nice my number is 765 465 8065 early morning or later afternoon because you guys are clueless too what iv done and am doing.
Old 05-21-2012, 09:13 AM   #40 (permalink)
mcrews's Avatar
Our mistake
your a Narcissist
ECO MODS PERFORMED:
First: ScangaugeII
