Old 09-05-2019, 08:34 AM   #711 (permalink)
Bill the Engineer's Avatar
Originally Posted by Tahoe_Hybrid View Post
if any one really really wants to do a hybrid swap i suggest getting one from a 2mode Hybrid
available in Hemi and LS2 (LS2 based aluminium block) flavors...
both V8 engines you will get about 25-30 mpg or so in a car
it's pretty much a drop in upgrade. for any RWD .. might need a STRONGER drive shaft though
these 2modes use a 4" drive shaft .. due to the massive amount of torque..
other wise you will end up twisting up your nuts and bolts
I originally considered using the system out of a hybrid Tahoe, but it wouldn't have given me nearly the 50+ mpg that the Prius system will.
The Following User Says Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020)
Old 10-16-2019, 08:29 PM   #712 (permalink)
Originally Posted by Bill the Engineer View Post
Plans are approved. Getting closer to groundbreaking. Wow, the hoops you need to jump through to get a house built here!
A little groundbreaking ceremony yesterday evening. The backhoe starts digging tomorrow morning!
The Following 3 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), me and my metro (10-16-2019), RedDevil (10-17-2019)
Old 10-18-2019, 04:32 AM   #713 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
The best I have gotten was 31MPG in MY city 26.7 highway and 28.8MPG combined (over 200 miles, 40 miles city/164 miles highway),
that is stock hypermiling with a 11 year old worn out battery
I don't think you will be leaving V4 mode often on that car (it weights 2,000 pounds less )
41-43MPH is the optimal fuel efficiency spot ( CVT mode) 45MPH+ it's on gear #4 and you lose quite a bit
that is how i'm able to get BIG numbers 100% stock (the engine is just idling at that speed )
I estimated you would get about 46-50MPG on that 6.0L V8 OR you will twist the chassis.up. with all that torque basically has 3x the power of a Prius.
the theoretical max on a flat level grade NO extra wind and other favorable conditions etc.. is 38-42MPG 36mpg 100% stock is more likely IRL
the coefficient drag on that firebird is horrible i suspect the 0-60 time will 15 to 20 seconds which means you can't use it on the highway(will not be able to merge safely)
2014 Toyota Prius C
0-60 MPH 10.9 sec
0.24 drag coefficient
on the tahoe it's nice the the 08 and 09 are not electronic governor locked 0-60 is 6.8 seconds
(My09 is electronic governor locked to 8.9 seconds)
GM started locking them after the unintended acceleration issue with toyota.....
Old 10-26-2019, 08:52 PM   #714 (permalink)
The house is underway! The garage opening to the right will be for the Firebrid. I can't wait to finish that car!
The Following 5 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), Daox (10-27-2019), RedDevil (10-29-2019), wyatt (11-28-2019), Xist (10-27-2019)
Old 10-27-2019, 12:16 PM   #715 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Congratulations!
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
The Following User Says Thank You to me and my metro For This Useful Post:
Bill the Engineer (10-27-2019)
Old 11-28-2019, 02:53 PM   #716 (permalink)
Couldn't resist putting the Firebrid in the new garage.
aerohead (06-19-2020), me and my metro (11-28-2019), slowmover (11-30-2019)
Old 12-01-2019, 10:19 PM   #717 (permalink)
teoman's Avatar
A3 - '12 Audi A3
You have more garage space than living space
The Following User Says Thank You to teoman For This Useful Post:
Bill the Engineer (12-02-2019)
Old 12-02-2019, 01:04 PM   #718 (permalink)
mannydantyla's Avatar
Aerokee - '97 Jeep Cherokee XJ sport
90 day: 18.22 mpg (US)
Scrambler - '74 Honda CL200 Motorcycle
90 day: 55 mpg (US)
awesome! I would kill to have that much garage space
what is "endless pool" ?
The Following User Says Thank You to mannydantyla For This Useful Post:
Old 12-02-2019, 10:40 PM   #719 (permalink)
https://www.endlesspools.com/?gclid=...gaAlwBEALw_wcB
The Following 2 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), RedDevil (12-03-2019)
Old 12-02-2019, 10:58 PM   #720 (permalink)
90 day: 30.18 mpg (US)
Every pool is endless if you are a bad enough swimmer.
The Following 2 Users Say Thank You to Xist For This Useful Post:
Bill the Engineer (12-14-2019), eco_generator (12-06-2019)
convertible, firebird, firebrid, hybrid
