Old 02-13-2020, 10:36 PM   #101 (permalink)
It's a good way to get rid of the a/t in one swell foop.
Kinda thinking of G10 into a Tracer wagon, because great utility in a small durable package and also a/t delete.
Old 02-13-2020, 11:11 PM   #102 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Swapping the 1.0 for the 1.3 shouldn't be as bad as the swap from 1.9 to 1.3 though if I find a good deal on a (local) g10.
I hear you on the utility. I really want to redo the tail as a hatch like basjoos has on his. I could hardly get the coroplast sheets in the car (folded hotdog style) through the front door.
I was talking to someone and they said the 3 cylinder lasted forever. How does that compare to the 4 cylinder? This one has ~150k on it.
Missed opportunity to say one of my motorcycles has a bigger engine than my car though (KZ1100)
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 02-14-2020, 12:16 AM   #103 (permalink)
Yeah, the '98 Metro 1.0 and 60-70 mpg vs GoldWing 1.1 with 33 mpg and VMax 1.2 with... who knows mpg, it's bad (doesn't get hypermiled )
Old 02-14-2020, 09:28 AM   #104 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I love that one!
Old 02-17-2020, 06:32 PM   #105 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
It was ~44 Degrees today and with some extreme (for me) hypermiling I was able to get my trip home from work (cold start on top of it! ) past 50 (50.58) mpg!
And some pictures. Kind of blurry since it is starting to get dark out.
1995 Mercury Tracer
Old 02-17-2020, 07:10 PM   #106 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
They're both good engines in the same family. Longevity should be the same.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 02-17-2020, 10:16 PM   #107 (permalink)
Oh no, I didn't see this thread in time, I'm sorry you lost the bet!
An instant 10% gain in mpg is to run xylene (135kBTU/gal) or toluene (134kBTU/gal) mixed with a little diesel (139kBTU/gal) to get a 136kBTU/gal fuel vs. gasoline (124kBTU/gal, might be lower than that due to winter fuel). Maybe you can bet someone else that you can hit 65mpg, and use xylene to help get you there :P
A possibly easy way to make small aero changes is spray foam. The stuff is a lot stronger than I expected, and it's easy to shape.
Nose taper I imagine does make some difference to A-pillar drag. If you built the hood bulge in that picture you linked, and then added some panels to blend it into the A-pillars, you would I think weaken the A pillar vortices.
At the end of the day your engine is really holding you back, 60 might not have been possible even with some extra aero help :/
The Following User Says Thank You to serialk11r For This Useful Post:
M_a_t_t (02-23-2020)
Old 02-23-2020, 04:09 PM   #108 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
I moved the driver side mirror from the metro to the mercury on Thursday night. Not the same as a mirror delete, but it is more aerodynamic for sure. To mount it I just cut the mounting stuff off for the metro and then put a threaded rod through it and with some big washers I inserted it into the door. I had to pop the mirror glass off to tighten the 2 nuts (no lock nut) inside the housing. The hardware was just what I found in the garage. Surprisingly it fits and blends in very nicely.
1995 Mercury Tracer
The Following User Says Thank You to M_a_t_t For This Useful Post:
MetroMPG (02-24-2020)
Old 02-23-2020, 11:51 PM   #109 (permalink)
Considering the latest gasser versions of the Escort in Europe had the 1.3L Endura-E POS, it doesn't seem so unlikely that a more elastic engine such as the G13 could fare better.
Old 03-05-2020, 08:55 PM   #110 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Engine is out of the metro. This thing is SUPER rusty! I was trying to avoid going underneath the car because of it, but I ended up having to go underneath to undo the rear mount and I ended up cutting the shift linkages because I didn't want to be pounding on the thing trying to get the pins out. I also figured that they would most likely need to be modified to fit the mercury anyway.
This was one of the more solid areas of the car and after I put the car on the stands and the front wheel on a cinder block I pushed the car as a precaution and the stands started going through the floor Once it stopped I put the jack back in contact with the only section still intact on the side of the car.
1995 Mercury Tracer
Gasoline Fumes (03-05-2020)
