Old 10-09-2008, 08:05 PM   #11 (permalink)
Originally Posted by Ford Man View Post
I've made a habit of checking my tire pressure during the first week of every month. I always know how long it's been since they were checked and it also makes it much easier to remember to do it.
excellent advice
my experience is that alloy wheels tend to be porous and leak air much faster than the old steelies
3 of my 4 cars have alloys
the 67 Camaro with steelies holds pressure the best, by far
Old 10-09-2008, 08:28 PM   #12 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
silverinsight2 -
Originally Posted by silverinsight2 View Post
I check them every day.
Yeah, those are good, but I think they are more for the general driving population. I had a set like those on sale from Radio Shack, but I didn't like them. If they would state "32 PSI", they wouldn't go red until maybe 24 PSI.
Therefore, I think for our high-PSI setups, we would need to have more precise versions and/or pick the highest PSI ones they offer.
Hrmmmm, maybe my experience was with the cheapy versions.
CarloSW2
American Solar Energy Society
Old 10-09-2008, 11:35 PM   #13 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by Tango Charlie View Post
Yup, that's what I've determined to do. Along with a fluid check.
Want to remind me too?
Old 10-10-2008, 12:15 AM   #14 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
I have those caps that tell you when the tires drop to 31 or lower (normal is 36psi or higher). The one downside is that putting the caps on and taking them off the tire results in a small loss of air and I'm not sure if the cap is really airtight to the valve. Another worry I have is they could be a source of air leakage.
I know I should check my tires at least once a month but I get lazy about it. With the last few tanks I've been getting, I think I need to look into it.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 10-10-2008, 09:54 AM   #15 (permalink)
Mine are 50 psi, and they go red at 44 psi. I got them on ebay.
I did have one that leaked once, the secret is to install and remove them by twisting the metal portion only, not the clear plastic cap.
The Following User Says Thank You to silverinsight2 For This Useful Post:
101Volts (08-14-2013)
Old 10-11-2008, 07:39 AM   #16 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Tires definitely need frequent checking.
Monthly is not nearly often enough in my humble opinion.
Weekly sounds good to me.
But I do get lazy sometimes.
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
Old 10-12-2008, 10:48 PM   #17 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
I had same thing happen to me a week ago, just from temp changes. I have been running my 35psi tires at 40. Well it dropped about 30 degrees outside over last couple weeks. I check tires once every 2 weeks. Everyone of them was down to exactly 26psi. 14psi drop just from ambient temps, crazy never checked enough before to realize they change that much.
The Following User Says Thank You to bbjsw10 For This Useful Post:
Old 10-13-2008, 06:23 AM   #18 (permalink)
Tire Geek
CapriRacer's Avatar
The temperature change should only have resulted in a 3 psi drop, so you have another problem! Nail?
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 10-13-2008, 07:38 AM   #19 (permalink)
Addicted
bbjsw10's Avatar
On all 4 tires exact pressure drop! I checked again 2 days later still holding 40psi.
Old 10-13-2008, 08:19 AM   #20 (permalink)
BBsGarage's Avatar
BBsRide - '06 Toyota Corolla CE
90 day: 31.64 mpg (US)
I'll be going out at lunch time to check mine.
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
