06-30-2008, 02:07 AM
What? THIS IS MY GOOD CAR
Homemade wind tunnel?
Why couldn't you use a peanut oil fog machine and a big fan for home wind tunnel testing?
Note: Wind tunnel assistant not included.
Honda...the economical, renewable resource.
06-30-2008, 02:13 AM
Pokémoderator
justpassntime -
Would you have to "scale" the wind speed to the scale of the model or ?!?!?!?
CarloSW2
06-30-2008, 02:21 AM
Bicycle Junky
I wish I had the space to build a full size one. Maybe build like a small steel building in the backyard of some future house and put a fan that could simulate 60mph winds on my actual car or something...
06-30-2008, 09:57 AM
EV OR DIESEL
My dad actually has a 5 foot (blade) diameter fan that can sustain 35 mph wind. Runs on a 2hp electric motor; barley starts on a 4kw generator but man is it nice when working outside. Hmmm
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
06-30-2008, 10:26 AM
I've thought about building a scale model wind tunnel. Just can't seem to find a model of the Jeep Cherokee.
A good example of a scale model wind tunnel setup can be found here.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
07-01-2008, 12:34 AM
Try the toy section...
Try the toy section at your local department store. The model wouldn't have to be a "model".
Check this out VINTAGE METAL TONKA JEEP CHEROKEE WAGONEER TOY TRUCK - eBay (item 140245515768 end time Jul-06-08 18:21:57 PDT)
07-01-2008, 12:35 PM
Harebrained Idea Skeptic
Each of those would put out turbulent flow, and together it'd be even worse. You can't put that fog through a small wand, so how are you going to target the area -- have it on a stand?
Yes, if one wanted to get real drag numbers. Look up "Reynolds number."
Yes, the model would have to be a model. Toys are extremely inaccurate, as proven by the link!
07-02-2008, 03:28 PM
Do want wind tunnel or data?
justpassntime,is there some specific info your seeking? I know you're aware of Reynold's Number effects, and how it effects model scaling in wind tunnels.A 1:24 Scale model would require a minimum of 480-mph wind in the test section to just simulate a turbulent boundary layer on your model .Anything short of that would yield meaningless data for you.If there's something specific you'd like to know about your car or potential projects,we may be able to help you out.I have a small tunnel I built for public demos but it's not a serious research tool.And for me,I can intuit and tuft-test in full-scale,faster and cheaper than I ever could with models.And the results are always valid 'cause its full-scale.Let us know.
07-02-2008, 04:51 PM
#9 (permalink)
Legend in my own mind
I know alot of you are DIY'ers, has anyone thought of retro fitting a spray booth as a wind tunnel? Or is it to small?
That would seem logical, plus you get the added benefit of being able to paint in it, if you maintain it properly.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
07-03-2008, 07:51 AM
#10 (permalink)
It probably wouldn't be too small in cross-section, but you wouldn't have sufficient empty space in front to ensure that the oncoming air was flowing properly.
