Old 08-16-2018, 11:54 AM   #131 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Anyone know which vehicles I might look at to get a belt driven brushless motor-generator? Was GM's Eassist belt driven?
Old 08-16-2018, 11:58 AM   #132 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
The GM system was indeed belt driven, you going hybrid with your K24?
My current Ecotec project...
My last Ecotec project...
Old 08-16-2018, 12:12 PM   #133 (permalink)
Not necessarily, or maybe not at first. I have various ideas about 12v production. Brushed alternators aren't terribly efficient, and I can think of several ways to improve that. I want to look at GM's system and see if I could use it as a better alternator.
Old 08-16-2018, 12:34 PM   #134 (permalink)
This looks promising:
https://www.ebay.com/itm/37390-2E930....c100005.m1851
Cheaper than the GM version:
https://www.ebay.com/itm/2007-07-Sat...ry!05446!US!-1
Old 08-16-2018, 02:46 PM   #135 (permalink)
90 day: 51.82 mpg (US)
Thanks. When Ecomodder tells you not to do an ecomod, it's probably a good idea not to.
Ha! If you have to ask, probably better to keep quiet and just do it.
After all, what did Colin Chapman say: "De-RPM-ify and add cost". Or something like that.
Ecky (08-16-2018)
Old 08-16-2018, 10:40 PM   #136 (permalink)
https://ecomodder.com/forum/showthre...tor-35003.html
E-assist uses a serpentine belt with a massive tensioner. Wants 72-115V.
Ecky (08-17-2018)
Old 08-17-2018, 09:07 AM   #137 (permalink)
If I'm only using it to generate <1000w, and typically <500w, I bet a normal belt should be fine. It will be under the same (or lower) loads as an alternator. I might buy one just to play with.
Unrelated, but thought I'd throw a picture in of my dash. Currently getting ~70mpg / 3.3l/100 in my typical 50% city 50% highway ~12 mile commute. No check engine light, lean burn works, auto-stop currently comes on sometimes so I need to tweak things a bit, engine needs to stay on in stop and go traffic.
Old 08-18-2018, 06:22 AM   #138 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Is there a thread somewhere about your mirror removal? Great thread, it should be a little rocket with the engine swap complete. Subscribed.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 08-19-2018, 12:19 AM   #139 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Why? Engine off if below 20 MPH, bump start!
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 08-19-2018, 08:19 AM   #140 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I thought these could be had for 80 bucks. Hnm.
