Old 12-28-2019, 11:36 AM   #51 (permalink)
I ordered this:
1k Watts, baby!
You are going to love this heater. I know I do.
Old 12-28-2019, 08:52 PM   #52 (permalink)
90 day: 29.44 mpg (US)
1k Watts, baby!
Oh hey, I didn't realize that we unlocked pet names... friend.
Old 12-30-2019, 04:36 PM   #53 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
I ordered this:
1k Watts, baby!
you know they make smaller compact AUX water pumps that run off of 12 volts Designed for cars?
also i suggest moving the air dam forward more if you can ...
also i suggest taking a Air dam from a tahoe hybrid (4") these are correctly designed air dams compared to running a "flat one"
they knew what they were doing since they got it down from 0.37 to 0.34 Coefficient drag with very "slight" modifications to the front end ..
(the air dam having the most to do with it as you can see it's flush with the bumper )
Old 12-30-2019, 10:05 PM   #54 (permalink)
Arguably a T'hoe hybrid air dam would require modification for a completely different make, model, and class.
Have you read academic papers comparing commercial air dams?
Old 12-31-2019, 04:48 AM   #55 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 40.37 mpg (US)
Had to google the width of a tahoe and mirage. Tahoe was 195cm and mirage 167cm,roughly.
Great idea though to use a "real" air dam but maybe from a smaller car?
Also, the price difference is presumably huge between diy and the other option, EVEN if bought from a scrapyard.
The Following User Says Thank You to iikhod For This Useful Post:
Xist (12-31-2019)
Old 01-05-2020, 08:23 AM   #56 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Good ideas. I know it used to be popular to grab the factory air dams off Chevy S-10's to use on other vehicles.
But perfect is the enemy of adequate! Or something like that. I know this cheap, easy airdam already works - ABA tested. I have a feeling a perfectly optimized one would be fairly small improvement.
Best fill-up to date!
63.4 mpg US = 3.7 L/100 km over 521 miles / 838 km (last bar just started flashing before I filled), calculated at the pump.
New mods added this tank: radio antenna delete (I just moved it inside the car - reception is worse, but good enough); WAI (warm air intake); engine kill switch.
The weather was unusually warm for early January: ranged from roughly -5C to +7C. Note that most (~95%) of my driving is on my usual very MPG-friendly secondary / scenic routes with a max 80 km/h / 50 mph speed limit.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
iikhod (01-06-2020), Xist (01-05-2020)
Old 01-05-2020, 02:45 PM   #57 (permalink)
Just hire a team of engineers and rent a wind tunnel! Oh my goodness! You are so lazy!
Old 01-31-2020, 10:44 AM   #58 (permalink)
Everything wrong with my cheap Mirage
Well, I've put about 2500 km on the car since I got it. Here's a complete laundry list of everything wrong with it. (Some of this will be repeat info....)
1) High km/miles for the year.
While not actually a "problem" with the car itself, it did have 145k km / 90k miles on the clock when I picked it up. An average car the same age would have had around 110k km / 68k mi on it.
What's funny is: I drive a lot less than average, so in about 2 years this Mirage will have less than average kilometers for its age.
2) Minor collision damage
That's what the car looked like when I got it. A relatively minor impact cracked & scuffed the bumper cover and busted all the mounting tabs on the plastic headlight housing. Minor, yes, but potentially costly: a repair using new parts would have been around $2k-4k. (This is probably the biggest reason the Toyota dealer dumped the car "as-is".)
I've since repaired the headlight housing and tried my hand at paintless dent repair on the quarter panel, which turned out reasonably well. The bumper cover still needs work.
3) Miscellaneous cosmetic paint damage
The car's paint condition is barely "fair" -- lots of chips and sandblasting, and there are miscellaneous scrapes, scratches & scars all around - 3 out of 4 corners.
4) Worn out brakes
It needed pads all around, and probably could have used new rotors & drums too (corrosion), but I attacked them with a wire wheel on the angle grinder and cleaned 'em up.
5) Busted radio antenna
Splintered fiberglass "mast" also contributed to paint damage on the roof (scuff marks from whipping from side to side).
6) Scored windshield
This one may count as nit-picking, but it looks like the previous owner didn't change a wiper blade when she should have, or some grit was trapped and she didn't notice. Either way, there's an arc scored into the glass - fortunately on the passenger side.
The rear wiper blade was also completely shot, so there's a bit of scoring on the back glass as well.
7) No spare key
I contacted the previous owner by e-mail and snail mail to see if she still has the second key, but she never replied.
8) Front washer nozzle plugged up
Did you know that you can independently aim this type of washer nozzle?? I didn't, until I took it off to clear the blockage.
9) Starting to rust
Yup: 6 year-old car is already needing minor rust repair. Stone chips above the windshield (pic above) that were left bare are the most obvious spots, but also the seam sealer/caulking on the bottom-inside of the driver's door is starting to peel off because of rust bubbling beneath it.
People: rust-proof your cars! Krown treatment or equivalent. And touch up yer stone chips!
10) So, so dirty!
The inside of the car was absolutely filthy... still is filthy. I vacuumed up the worst of the loose crap, but I'm going to remove & shampoo the seats and carpet in the spring.
11) Winter tires only
Given the current season, it's nice that the car came with chunky winter tires installed. But just like the spare key, the summer tires are AWOL. Or they were worn out and were thrown out at the autumn changover. Either way, rats.
12) Clutch out of adjustment
The engagement point was too high. Fortunately, it's a cable, and can be adjusted. The clutch itself is still healthy -- I think most of the km on the car were highway, based on the stone chips/sandblasting of the front end.
13) Expensive to insure
Holy crap! For 3rd party liability insurance alone, it's about 40% more expensive than my 2000 Metro, and almost twice as much as my 30 year old Miata! Stop crashing Mirages, people, or I won't be able to afford this exclusive little club!
14) It's a FSP
Compared to the winter beater Metro, it's a Fuel Sucking Pig! It's heavy, draggy, and it has a huge, thirsty engine. Cruise control is nice, though, and I'm enjoying the hilariously squishy soft suspension much more than I thought I would. I must be getting old.
But I'm having fun with it. I'm looking forward to the return of mild weather to see what kind of MPG it's capable of. I think a 70 MPG US tank is possible in ideal conditions.
Lastly: it's been a while since I had a car I could just hop in and hit the road without wondering what's going to break next, and should I bring my tools with me? That's very nice.
ID:	27504   Click image for larger version
ID:	27505   Click image for larger version
Old 02-18-2020, 02:17 PM   #59 (permalink)
4th fill
4th measured fill-up = 59 MPG US / 4.0 L /100 km over 763 km / 474 miles.
Not bad, considering the weather's been colder than last tank, and includes a couple of short freeway trips at higher than usual speeds for me (woulda beaten 60 MPG for the tank if not for the need for speed!).
HOW COLD WAS IT??? I used the seat heater one day... for the 2nd time ever since I got the car.
Again, keep in mind much the great MPG comes from driving in pretty ideal conditions at moderate speeds (rarely do I hit 60 mph / 100 km/h).
Old 02-20-2020, 09:21 AM   #60 (permalink)
If it's that cold, are you getting denser fuel in the tank that would increase your capacity?
Had a big deal at my local supplier where they got sued for not dispensing correctly on hot days. Apparently not everywhere has temperature compensated metering
