12-30-2014, 08:52 PM
#11 (permalink)
ALL UP ON THE INTERWEB!!!
Originally Posted by Cobb
It was as easy as inserting penis into second hole.
LOLZ!! she liked it
Thanks,
Victor
12-30-2014, 09:43 PM
#12 (permalink)
Growin a stash
Haha what the heck Cobb? Can't go editing your posts like that, now V looks crazy.
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
12-30-2014, 10:38 PM
#13 (permalink)
V is crazy, like me.  I had google speech on and it went though on that one. Didnt know it til I got the email notification.
The Following User Says Thank You to Cobb For This Useful Post:
12-30-2014, 10:44 PM
#14 (permalink)
ME_Andy Haha what the heck Cobb? Can't go editing your posts like that, now V looks crazy.
I'm OK with looking crazy:
I'm definitely crazy like you, COBB
Edit: on a more serious note, is this phev conversion thing something that can be "slapped" onto just about any car? I know nothing about this deal...
Thanks,
Victor
The Following User Says Thank You to vrmouseyd15b For This Useful Post:
12-31-2014, 10:36 AM
#15 (permalink)
It can be slapped into any hybrid car and back feeds the hybrid system so car uses mo electric than gas. Better mpg is the result.
12-31-2014, 03:47 PM
#16 (permalink)
That is slick! Too bad I'm too poor for a hybrid
Thanks,
Victor
12-31-2014, 10:01 PM
#17 (permalink)
Dude, you have built a few hondas. Im sure you could of easily afforded a used Insight, Prius or some over hybrid that came and went. Same stuff, different day. Once you get the car stuff figured out you just install the big box in the trunk with the batteries, converter, bms, charger and wires. Run a switch, run a power cord, run a lead to the ecu for a ready signal if available. Once you turn it on just drive and get an instant boost of mpg and extended use of EV mode if available.
Thanks,
Victor
12-31-2014, 11:52 PM
#18 (permalink)
haha! I guess it's more the fear of not being able to fix a problem with the electronics (or maybe the electronic nannies just piss me off  )
Happy New Year!
Thanks,
Victor
01-01-2015, 12:00 PM
#19 (permalink)
A gen 1 insight can be a fustercluck of a project. They usually suffer from several problems, bad ima battery, bad or missing grounds, leaking exhaust, bad cat, bad o2 sensor, clogged vtec filter, 2,3 sychros need replacing, ISB needs replacing, etc.
You can bypass the ima battery, try balancing it or replace it for 2 grand with a new one. The rest of the stuff Im sure you have done already. Sometimes the IMA errors are from a rat snacking on the wires inside the battery unit.
01-01-2015, 12:07 PM
#20 (permalink)
^^^^^^^ work,work,work ugh.
'Guess I'll just stay old-skool. I've actually found an '81 civic wagon up in Iowa that I'm starting to get a hard-on for (I was born in 1981 - that would be just too cool to have a car my age! ) Runs and drives, and prolly more expensive than a hybrid
Thanks,
Victor
