Old 02-03-2014, 01:34 PM   #71 (permalink)
darcane's Avatar
Originally Posted by Detail Man View Post
Darcane, did you resolve the issue with your Ultragauge cutting off when you hit the kill switch?
I have not. But I haven't really worried about it too much. It just underestimates my mpgs slightly on the UG. Fuel used is right on, but it's misses a few miles per tank.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 02-04-2014, 05:22 PM   #72 (permalink)
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
The Torque app does the same thing. It cuts out when I first kill the engine. The speedometer and odometer continue to work when the engine isn't running, which is more important to me.
I hate watching my battery voltage drop when EOCing. It goes from 12.6 to 11.9 after 30 seconds with the headlights and heater off.
Old 02-04-2014, 08:32 PM   #73 (permalink)
02 Civic - '02 Honda Civic LX
90 day: 40.32 mpg (US)
Kill switch is installed. So far I have been an ecodriver, now I am officially an eco "modder". Tried it out this evening and it works very well. Way safer than key off/on. Thanks for the help guys.
Relay is ziptied to a cable in the upper left corner. I used spade clips in case I ever want to uninstall the mod.
Red switch is the safety switch. I used an illuminated one so I could glance and see if it was on. The black switch is the kill switch.
The Following 2 Users Say Thank You to Detail Man For This Useful Post:
pletby (09-06-2016), sarguy01 (02-04-2014)
Old 02-04-2014, 08:39 PM   #74 (permalink)
sarguy01's Avatar
Looks good! I would have used an illuminated switch, but I had a regular one in my parts drawer. I may wire an LED in and mount it on the dash someday.
Old 09-08-2015, 11:16 AM   #75 (permalink)
Donahue's Avatar
White Lightning - '04 Honda Civic HX
90 day: 40.5 mpg (US)
bump because this was such a helpful thread.
Old 09-08-2015, 01:40 PM   #76 (permalink)
I don't understand why a relay was needed instead of just a momentary switch.
I've got a 4 wire switch that I haven't installed yet on the Acura that simply disconnects the 4-wire harness that goes from the alternator to the ECU. This was the only way I could get the Acura to die without a MIL or killing the instrument cluster. It still runs with the crankshaft position sensor disconnected and throws a MIL.
Old 09-08-2015, 01:47 PM   #77 (permalink)
Donahue's Avatar
im guessing the relay is not needed for amperage reasons, but i dont know if i would want the new circuit to have to flow to wherever i mount the switch, and then back, just to run without a relay. relays are cheap though. I will also likely be installing a momentary switch.
Old 01-10-2023, 02:42 AM   #78 (permalink)
EcoModding Noob
Christian's Avatar
City Civic - '02 Honda Civic Coupe LX
90 day: 34.12 mpg (US)
Shitty Ranger - '99 Ford Ranger 4x4 XL Single Cab
90 day: 16.65 mpg (US)
I have an 02 Civic, and I’d love to do a kill switch just like this for EOC.
Problem is, I have no clue how to do anything electrical-related, have any tips for not breaking my car? Haha
