Old 01-22-2014, 08:21 PM   #61 (permalink)
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
Originally Posted by darcane View Post
Yep, that is the one you want.
I actually snipped it on the other side of that connector. In hindsight, that may not have been the best choice, since you have to disconnect that connection and pull that harness through the firewall to remove the engine. It would have been easier if I snipped it right about where you have your screwdriver.
Sweet. Now I just need the relay and switch to arrive!
Old 01-25-2014, 03:30 PM   #62 (permalink)
sarguy01's Avatar
Done! It does take 2-3 seconds of holding the switch for the engine to fully shut off. I also wired a safety switch into mine. I need that switch on before I can push the momentary switch. I wanted to be able to turn it off so I don't hit it by accident.
Now I need to practice bump starting at speeds and coming up to stop signs. I tried bump starting at 5 mph or so and the car came to a stop, without starting. Oops...
Old 01-26-2014, 09:02 PM   #63 (permalink)
darcane's Avatar
Ninja 650R - '06 Kawasaki Ninja 650R
90 day: 52.02 mpg (US)
B*tch - '01 Honda Civic HX
90 day: 38.09 mpg (US)
Ms. Hyde - '06 Cadillac CTS V
Sports Cars
90 day: 16.93 mpg (US)
Heh, yeah, it can do that. What gear were you in?
I typically bump start in 5th down to about 20mph, 4th down to 10mph, and use the starter if I'm below that.
2001 Civic HX Mods
Past Cars:
CTS-V
2003 Silverado Mods
Old 01-27-2014, 07:24 AM   #64 (permalink)
sarguy01's Avatar
I was in 2nd at 5 mph. Next time I'll just hit the starter when going that slow.
I also did most of the bump starting in 4th. I'll try 5th next time.
Old 01-27-2014, 11:17 PM   #65 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I regularly bump start it rolling backwards out of the driveway...I figure any time I can avoid using the starter, saves wear and tear. So, it can be done at very low speeds.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 01-27-2014, 11:25 PM   #66 (permalink)
sarguy01's Avatar
It can, I just need practice! Though, I can start mine in reverse fairly easily rolling down my driveway backwards...
Old 02-02-2014, 03:58 PM   #67 (permalink)
02 Civic - '02 Honda Civic LX
90 day: 40.32 mpg (US)
Sarguy, got any pics of the final install? I have an 02 civic lx and was curious where you put your switches and relay. Thanks to this thread I've identified the yel/blk wire behind the glovebox, and am planning on adding a kill switch soon.
Darcane, did you resolve the issue with your Ultragauge cutting off when you hit the kill switch?
Old 02-02-2014, 04:06 PM   #68 (permalink)
sarguy01's Avatar
Here you go...the safety switch is next to the fog lamp switch and the momentary switch is the silver one.
The Following User Says Thank You to sarguy01 For This Useful Post:
California98Civic (02-02-2014)
Old 02-02-2014, 09:03 PM   #69 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Exceptionally clean and good looking. I like the attention to little detail a lot.
Old 02-02-2014, 11:52 PM   #70 (permalink)
Thanks! That's exactly where I was thinking of putting the momentary switch. The safety switch is a good idea, given that the kill switch could get bumped in that location.
