Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 09-22-2012, 12:45 AM   #51 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
wrong again thats 3 strikes
...."By blocking the air to the MAF you are changing the calculation for load so it will read lower and increase timing that will help in mid-low load situations but if your timing map was close to the point of knocking in the high load area it can cause problems. ".....
no
now
pay attention
if you "block" airflow to the MAF sensor then the MAF sensor will
correctly report the reduced amount of air that is does
receive
nothing will change
timing will remain correct load will be correct for the amount of air measured which will be the amount of air that the engine actually receives.
see my previous posts in this very thread for more text on the topic
stop this
it makes all of you look very silly
Old 09-22-2012, 05:39 PM   #52 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
receive
nothing will change
stop this
I agree with what you said but only if the block is far enough before the MAF that it will see the total air flow being pulled through the intake. BUT if the block is placed to where the MAF sensor is in a space of dead air it will not read the total air being consumed by the engine.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 09-22-2012, 10:10 PM   #53 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
you do know the pic of his MAF showes air straighteners(1/2"x1/2" square that's 1/4-1/2" in depth) the maf is sitting some where aft of those; probably by the same distance, all that plate is doing is creating a vacuum in the intake behind it causing any blockage of the MAF to be none.
BTW. some people think removing the MAF air straightener to give them a performance increase(i'm talking hp)
Old 09-22-2012, 11:04 PM   #54 (permalink)
mwebb's Avatar
turbulence
the effects of turbulence that may or may not be induced by whatever in the air stream prior to the MAF sensor
will
be
Unpredictable and will vary depending on the amount of air flowing in the duct at the the time ...
i have already covered this in an early er post in this thread .
in any event the OP's system has not set a fault for fuel trim either way so the effects of turbulence in his system
(if turbulence is actually present )
have not exceeded the fuel trim correction limits which are designed to keep the system at
stoich or 14.64 to 1 , so his system is at
but
i have not yet brought up the fact that blocking air flow to the intake will
NOT improve losses related to
suction throttling losses
and the effects will be increased as flow increases
so while the effects of turbulence are UN predicable
the increase in suction throttling losses will always
decrease
fuel economy .
no matter how you add this up
it
is
not
ever
going
to improve fuel economy or increase power output
you can however
reduce MAF signal and Calculated load simply by placing a resistor in the signal line or
on the 5v reference IF the MAF sensor is analog and not digital
and that will not be dependent on the unpredictability of turbulence and there will be no suction throttling losses induced by it
having said that
do not do it -
you have no clue as to the additional possible side effect you will cause
which have been partially addressed in this thread
Old 09-27-2012, 07:43 AM   #55 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
As a TEST...I installed this block in my Focus intake. Weather won't permit testing a full tank...this was just a test to see how it runs. Runs about the same...anyone not knowing it was in there...wouldn't likely be able to tell the difference.
Made of a heavy plastic funnel...just forced it into the corrugated part of the intake tube after the MAF.
Opening in cone is around 1 1/4"...which is approx the same as a half throttle opening (45*) at the throttle body...so in most situations it just acts like a dirty filter ABOVE a certain throttle opening? Used around .61 square " per L from above posts as a guide.
Scangauge shows high mpg for first mile on highway after leaving town...but it settles down after that.
Will reinstall and test next summer.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 09-27-2012, 02:30 PM   #56 (permalink)
The suspense will kill me first.
Old 09-28-2012, 01:21 AM   #57 (permalink)
mwebb's Avatar
shake your head NO- up wake
do you really think that this will improve Volumetric Efficiency or reduce suction throttling loss
shake your head no
do your really suppose that there is there any way that your tampering can improve anything ?
shake your head no
why do you persist with what you have been shown can not function As you desire it to ....
you can not "hope" for an improvement , you must operate in
reality , unlike our current government
up wake
Old 09-28-2012, 04:05 AM   #58 (permalink)
First...I have no idea WHETHER this block will improve mpg...but I have reasons to believe it MIGHT.
The mod is easy to install and easy to reverse.
IF I do see an mpg gain...I MIGHT..........then........try to explain it.
Or better yet....I will let certain parties explain why it doesn't work after it does...as with the recent cone filter mod I tested.
PLEASE...remain as you are until testing is completed. Thank you....
Old 10-26-2012, 08:59 PM   #59 (permalink)
mwebb's Avatar
your theory is not accurate
i would be interested to see how you expect increasing suction throttling losses and decreasing volumetric efficiency are
supposed
to
improve
anything
especially,
fuel economy
specifically
BSFC at any load or rpm
here on the planet Earth in any car powered by an internal combustion engine .
ready
begin
Last edited by mwebb; 10-26-2012 at 09:01 PM.. Reason: your test will show you what most already know
Old 10-27-2012, 12:41 PM   #60 (permalink)
The PRC.
Your post could stop here to be honest.
