07-15-2013, 06:01 PM
#221 (permalink)
Ultimate Fail
Originally Posted by bschloop
just finished my fighter bike. it belongs here I think.
Cool ! Are you going to paint the inside ( i see an advertisement ! )
Thanks for posting the pic - i would have missed it.
07-15-2013, 09:21 PM
#222 (permalink)
Ultimate Fail
This isn't a military theme paint job, but just to let you guys know this is done using regular water base ( ! ) acrylic craft paint on my car as a test.
The paint has remained on the car throughout a year of rain and Texas heat, all without peeling or fading. I used no primer at all, but the paint had a dull finish when i painted this .
I can still remove it though using soap and water and some scrubbing. Cheap, Eco-Friendly ( waterbase non toxic acrylic craft paint ) and removable.
Beats using spray paint !
The Following User Says Thank You to Cd For This Useful Post:
07-16-2013, 02:23 AM
#223 (permalink)
Lots of Questions
Cd, I think the links are broken
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
07-16-2013, 03:53 AM
#224 (permalink)
The paint-like product I like is PlastiDip.
I've used it so far on a bike frame and car wheels. If you search on YouTube you'll find it's a surprisingly durable, low-cost version of a full vinyl wrap. Available in any color you can mix up, with top coat glossifiers, metallisizers and pearlizers—not to mention florescent colors.
I plan to use it to undercoat my panel van, instead of POR-15 or Rhino coating. It's all been media blasted but there would be a ton of work to get it ready for paint. So I will pressure wash it and spray 4 or 5 coats of PlastiDip. And the Rader Mag wheels that are an aluminum center with steel rim will be Real Aluminum with a Pearlizer.
There's the original plastiDip which it thick enough to dip tool handles in, then there's Plastip S which is thinned 50% for spraying, but with 100% more pigments so it still covers well.
07-16-2013, 02:05 PM
#225 (permalink)
Always Too Busy
1) 179108_605890916098391_440949298_n | Flickr - Photo Sharing!
2) small1 | Flickr - Photo Sharing!
Here are his links
Nissan Leaf driver? Join me in Team Leaf and feel smugly superior about our MPGe
Current Car: White Lightning
Retired Car: Betty White
The Following 2 Users Say Thank You to Flakbadger For This Useful Post:
07-23-2013, 06:55 PM
#226 (permalink)
MPG Militia HMV-25E80+A
Just about to paint my eighth oil rig on the side of my car for 800+ gallons saved over EPA . Any suggestions on the 1000 gallon symbol?
07-23-2013, 09:00 PM
#227 (permalink)
I am probably going to eventually replace the doors with something sturdier. They are coroplast election signs, and they tend to warp in the sun.
07-23-2013, 09:33 PM
#228 (permalink)
Wiki Mod
Do an off shore oil rig
07-24-2013, 01:43 PM
#229 (permalink)
Hypermiler
You've been spotted!
So many questions....
The Following 2 Users Say Thank You to PaleMelanesian For This Useful Post:
07-24-2013, 06:07 PM
#230 (permalink)
I commented with a plug for EM. That's two MPG Militia machines shared on Jalopnik! Can we get a third?
