Old 10-08-2010, 09:41 AM   #601 (permalink)
All you wrote is already done in Obduino32K
comunication is same.
What version do u use?
try uncoment
#define DEBUGOutput
it will show on what step iso initialization is failing. please try all 3 modes and remember what it displays.
Old 10-08-2010, 05:09 PM   #602 (permalink)
I use obduino32k v179. If I uncomment DEBUGOutput and try to upload, i get error line 3641 "lcd_gotoXY" not defined .. and i change it to "lcd.setCursor" I dont know its this right or not, however now I can upload and if I try in car with ISO9141 protocol and I get "Failed! 8". ISO_14230_fast I get Failed 4 and ISO_14230_slow Failed 8.
Old 10-16-2010, 05:23 AM   #603 (permalink)
It looks like your car is not responding
I do not have any passat 1997 to check if my system works with it. I look around at work.
May be you can test with other car to check if it works and you build everything fine?
Old 10-18-2010, 01:19 AM   #604 (permalink)
I tested in mazda mx5 and it works fine.
Old 10-18-2010, 02:52 AM   #605 (permalink)
So we need exact protocol instructions your car is using to try adapt obduino to your car.
Also it would be great to check if your car is responding anything.
Or may be do you have VAG-COM 401 cable or similar? VAG-COM software has function to detect wich OBD2 is supported.
Old 11-08-2010, 07:27 PM   #606 (permalink)
Big Font
Thanks for adding the Big Font Code. It is quite a fun addition.
I checked in a slight change to the google code to make it more for my liking, and maybe someone elses. It is controlled with the define #BIG_font_hybrid.
It will make the display on the Average fuel consumption page look like
## ## ## 6.32
## ## ## AVG L/K
so you can see both your average in a Big Num format and still see your instant as well in the top right corner.
Old 01-11-2011, 02:06 AM   #607 (permalink)
there is error in Short/Long time fuel trim PIDs calculating:
Code:
  case STFT_BANK1:
  case LTFT_BANK1:
  case STFT_BANK2:
  case LTFT_BANK2:
    *ret=(buf[0]-128)*7812;  // not divided by 10000 for return value
    long_to_dec_str(*ret/100, decs, 2);
    sprintf_P(retbuf, PSTR("%s %%"), decs);
    break;
all results are shown in between +-3
Code:
has to be replaced with (tested)
Code:
    *ret=buf[0]; // Added to avoid 65536 limitation in next operation
    *ret=(*ret-128)*7812;  // not divided by 10000 for return value
or to leave only *ret=(*ret-128)*7812;
becouse *ret is already assigned *ret=buf[0]*256U+buf[1];
or any other solution that do not increases memory consumption
Old 01-27-2011, 05:15 AM   #608 (permalink)
For "eimix":
For internal/external temperature where is placed the KTY sensor ?
Old 01-27-2011, 05:27 AM   #609 (permalink)
It is not in car.
You can get it in any nearest electronic/radio parts shop.
googled for Romania
Search results - SOS electronic
or
Senzor de temperatur
Or did i missunderstand your question?
Old 01-27-2011, 05:31 AM   #610 (permalink)
Sorry for confussion .
In OBDUINO schematic where is conected KTY ?
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
