Old 06-30-2010, 11:04 PM   #3521 (permalink)
Boy...sorry to here this Paul.... It would hurt me too
I Corinthians Ch 15
Old 07-01-2010, 08:31 AM   #3522 (permalink)
Sorry mate, I lost my Mom in very similar circumstances, I won't pretend to know how you feel, I only know How I felt.
Old 07-04-2010, 04:53 PM   #3523 (permalink)
Rev 2D uses heavy duty PCB powerboard ?
In the Open ReVolt/Fab Files is "Note: Rev 2D uses heavy duty PCB
powerboard as opposed to milled copper/fibreglass boards".
What is heavy duty PCB powerboard? Is it something other than 4 oz.
copper/ per sq. ft. double sided pc board like Paul H was selling?
I have to make another one.
Thanks, Larry Reiss
ID:	6287   Click image for larger version
Old 07-04-2010, 05:19 PM   #3524 (permalink)
Cutter Dia. for milling power board traces?
Can anyone tell me what the width of the cuts are between the traces
on the power board? Some one wrote that they used a 1/8 in. vee shaped
cutter. So it's unclear to me what the width of the cuts actually are. It all
depends how deep the cut is.
On my power board that had the magic smoke escape, I milled the cuts
.050 in wide. Maybe that wasn't wide enough for 180 volts.
Thanks, Larry Reiss
Old 07-04-2010, 05:30 PM   #3525 (permalink)
PaulH
MPaulHolmes's Avatar
My cuts are probably 0.08" wide. I don't know if 0.05" would be enough or not for 180v. Maybe there was a wisker of copper that bridged it, and then that allowed a torrent of current to keep going? I don't know what I"m talking about though.
The rev D board is 4 ounce copper on each side. It's just made by an actual board house, with solder mask and stuff. It's really nice. I've got to make myself one of those buggers.
kits and boards
Old 07-05-2010, 01:17 AM   #3526 (permalink)
Heat related question
So I got my Logisystems Revolt hybrid up and running
Great use of the power stage considering there was nothing really wrong with it. I took the car out and everything is good, except for heat.
There is a fairly good heatsink installed on the LS power stage, except that its fins could be bigger. Other than actual physical alterations though is there a possibility of altering some of the PWM or other software parameters that would decrease the heat output?
If not then can someone suggest relatively easy thermal management solutions (read cheap)
thanks!!!
Old 07-05-2010, 03:50 AM   #3527 (permalink)
jackbauer's Avatar
does the LS power stage use mosfets or igbts? I suspect i read somewhere its igbts. If so your probably not driving them at full capacity with a stock control board. What gate resistors are you using? Also consider another resistor and fast recovery diode in inverse parallel to aid turn off.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 07-05-2010, 02:14 PM   #3528 (permalink)
heta related question
the gate resistors were built into the power stage of the LS board and yes the board uses IGBTs.
A forum member on DIYelectric said i could just gofrom the control board to the power stage with no other mods, which is right but the heat is a bit of a problem for speeds over 45 and if i have to merge with traffic forget it, the heat gets to where it cuts back very quickly.
i'm not an engineer so if i have to make modifications can you tell me in a way i'll understand?
thanks!!
Old 07-05-2010, 06:18 PM   #3529 (permalink)
AHHH....so thats what you mean
ok, so i found your diagram for the circuit using an IGBT setup.
let me figure this correctly.
the way i have it now, the control board (revolt), i use one of the GR pads to run a line from the control board to the LS power stage. I did this because the Gate Resistors are in the power stage of the LS controller.
For the LS, there is a single pin that this line was soldered into.
If i go with the IGBTs, should i just make a small board to insert between the control and power stage so that it will produce the same signal effect?
Name:	my circuit.JPG
Old 07-07-2010, 01:14 PM   #3530 (permalink)
Joe
thanks!!!
if there are IGBTs in there, the gates should probably be driven up to 15v. if you're using the control board output to drive them, the cincon DCDC is providing the gate power and it's only 12V for the mosfets. At 12V, the IGBT's won't turn on all the way and will create a lot of heat. I think there is a version of that DCDC that has an output of 15V.
There's also the gate resistor thing mentioned earlier, but sounds like that's hard wired in...
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
