07-07-2014, 06:21 PM
#6641 (permalink)
PaulH
I'm getting nothing on this controller's serial. I think I made some changes. I haven't tested the serial since before leaving for Washington in May (at which time it was working. haha). I need to see what I may have commented out or whatever.
07-07-2014, 06:43 PM
#6642 (permalink)
PaulH
Actually, it is working for me (I had opened the wrong port). It's not echoing back to the screen, but is responding to commandsf (so, it doesn't show me typing config, but is writing all the stuff on the screen). Did you do all lowercase "config"
and hit enter afterwards?
If you keep hitting enter, does it keep saying the same thing? Or has it frozen up?
07-08-2014, 01:54 AM
#6643 (permalink)
EV Connoisseur
CHECK.. it was the linefeed.
07-08-2014, 01:56 AM
#6644 (permalink)
EV Connoisseur
Does it matter which current sensor connects to which connector on the board?
The Following User Says Thank You to flores For This Useful Post:
07-08-2014, 07:07 AM
#6645 (permalink)
Hi Paul,
I have ordered one of those Picket things,
I expect i will be sending you lots of questions!
I'm looking forwards to being able to spin the rear tires
Question - what happens if I give it too much welly with an LSD - both tires spin
It should kick sideways - I hope I can catch it before the hedge does
The Following User Says Thank You to duncan For This Useful Post:
07-08-2014, 07:13 AM
#6646 (permalink)
EV Connoisseur
Originally Posted by duncan
Hi Paul,
Its not that hard.
See my pictures.. just slot it on.. start mplab, choose programmer, choose device, load file, program.. DONE.
07-08-2014, 08:00 AM
#6647 (permalink)
PaulH
Hi Flores. Nope, it doesn't matter which one plugs in where. I think the lengths work out best if the shortest sensor plugs into the connector that's closest to the copper sheets. Then the medium length sensor wire in the middle connector, and longest wire to the bottom connector.
"Question - what happens if I give it too much welly with an LSD - both tires spin."
What??!! Haha. What is welly and LSD?
The Following User Says Thank You to MPaulHolmes For This Useful Post:
07-08-2014, 08:05 AM
#6648 (permalink)
EV Connoisseur
07-08-2014, 09:17 PM
#6649 (permalink)
Dreamer
I'll take a stab at this one. Welly probably refers to rubber boot / gum boot / waders, you know the ones. Black knee high rubber boots for splashing in mud and puddles.
Giving it more welly is pushing the accelerator more. Pushing you foot further on the accelerator or pushing your welly further. Thereby giving it more welly.
Just a guess.
The Following 2 Users Say Thank You to Astro For This Useful Post:
07-09-2014, 04:54 PM
#6650 (permalink)
EV Connoisseur
Took the cap out and applied the tape..
Back on the coppersheet..
and the controlboard back in:
