Old 08-21-2014, 10:18 AM   #6871 (permalink)
EV Connoisseur
Can we buy it anywhere? Then I'll take it apart
Old 08-21-2014, 10:29 AM   #6872 (permalink)
PaulH
MPaulHolmes's Avatar
Haha no. Its better suited for the megawatt range. It won't be replacing regular old inverters.
kits and boards
Old 08-27-2014, 07:45 PM   #6873 (permalink)
PaulH
Jedsmd, did you ever try the new code I sent? There were fairly significant changes to the structure of the loop, and I was wondering how it sounded (the hiss), and if it drove any different.
kits and boards
Old 08-28-2014, 11:53 AM   #6874 (permalink)
PLUGnGO
jedsmd's Avatar
Sorry Paul I 've been distracted on other stuff. I will put the code in right now. I got quite a bit of running around to do today so it will get a good test.
Edit:
First reactions; it works, its smooth, it is surprisingly quiet.
The Following 2 Users Say Thank You to jedsmd For This Useful Post:
MPaulHolmes (08-28-2014), thingstodo (08-28-2014)
Old 08-28-2014, 05:30 PM   #6875 (permalink)
PaulH
Phew!!!!!!!!!!!!! It's quieter because the spread spectrum is now 7-11KHz, so the hiss is composed of less audible frequencies. It should create more heat, though. Does your battery gauge meter go crazy while it's running?
kits and boards
Old 08-28-2014, 09:46 PM   #6876 (permalink)
PLUGnGO
jedsmd's Avatar
The sound level is nice. It is enough that you can tell when you apply power, but not annoying at all.
The meter was not disturbed by the controller. However I have the parts for the noise filter now, so I intend to go ahead and install it.
Driving is very smooth, overall it feels really solid.
4x4EV (09-03-2014), MPaulHolmes (08-28-2014)
Old 09-03-2014, 09:29 AM   #6877 (permalink)
EV Connoisseur
okay.. I was away for two weeks (holiday in Tuscany Italy) but now I'm working full force on the raspberry software.. saving settings now works.. and i'm adding logging of the rtd data to a file for analysis.
This weekend the controller is going back in the car !!
The Following 2 Users Say Thank You to flores For This Useful Post:
MPaulHolmes (09-03-2014), thingstodo (09-03-2014)
Old 09-03-2014, 09:45 AM   #6878 (permalink)
PaulH
I shiuld probably send you the most recent code too. Was it a standard 0-5k throttle, with 0Ohm being zero throttle?
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
flores (09-03-2014)
Old 09-03-2014, 12:52 PM   #6879 (permalink)
EV Connoisseur
Yes.
Old 09-07-2014, 02:53 AM   #6880 (permalink)
Back again
Hi Paul,
I'm back - not completely right but I've managed to get some decorating done so I'm allowed to look at my car
Some damage in transit
Nothing serious
I have plugged in what I can,
So there is the IBGT's and their monster capacitor,
And a control board
What is the other board for???
(the one that came completely loose in transit)
I need to make some end bits to support the cables, that will support the current sensors
Then I need to identify the wires on the other two boards
I have included pictures of the Puma my brother made,
I've no idea what I'm going to do with it
I found some water cooling plates on Hobbyking
https://www.hobbyking.com/hobbyking/...dProduct=21192
They are $16/pair
I intend using one under each IGBT
I'm thinking of using a windscreen washer bottle with a built in pump and returning the water via a small cooler under one wing (fender?)
ID:	15752   Click image for larger version
ID:	15753   Click image for larger version
ID:	15754   Click image for larger version
ID:	15755   Click image for larger version
ID:	15757   Click image for larger version
ID:	15758   Click image for larger version
ID:	15759   Click image for larger version
ID:	15760   Click image for larger version
The Following 2 Users Say Thank You to duncan For This Useful Post:
jedsmd (09-07-2014), MPaulHolmes (09-15-2014)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
