Old 10-31-2020, 06:59 PM   #191 (permalink)
Ecomodding Apprentice
Originally Posted by mpg_numbers_guy View Post
Have you noticed a measurable improvement from the dimpling?
I don't measure as such, regular driving variables do not permit this but the bonnet and bumper reduce net drag by .98%, 3.1% if all non-negative pressure areas were covered
The Following User Says Thank You to Nathan jones For This Useful Post:
TexasCotton (11-01-2020)
Old 11-28-2020, 11:59 PM   #192 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Where do you get your carbon fibre from?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 12-07-2020, 09:09 AM   #193 (permalink)
Here in the uk, I use easycomposites, in bulk I find it's good value for money and they also stock the 200g glass in a cloth fabric where most just have woven roving
....a couple of very good results when computers were still in the car I found on my phone. I don't recall the driving enviroments, most likely extra urban and above mean 25c. They should thermally isolate the batteries in cold climates
next year I hope to make the undertray. The guy at the mot says I can't change the roof so I will make a dimpled skin for it and a cf rear hatch, aramid rear bumper and various brackets. I will also try structuring more and unidirectional carbon on unseen parts, it most likely will go round corners and hand lay easier. I found vacuum takes longer and goes wrong
And an aramid dash and door cards if there's time
ID:	29711   Click image for larger version
TexasCotton (12-07-2020)
Old 12-07-2020, 11:52 PM   #194 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Cut
Old 12-07-2020, 11:53 PM   #195 (permalink)
Convert
The Following User Says Thank You to TexasCotton For This Useful Post:
Nathan jones (12-09-2020)
Old 12-09-2020, 11:58 AM   #196 (permalink)
Very good, except for the steel
Old 12-25-2020, 06:32 AM   #197 (permalink)
Have a great xmas everyone
Here is part of a tubular racking system made from aramid kevlar/carbon. Once cured it is very strong and light. I was planning a car respray next week but I will miss the roof and fabricate a multiple vortice skin (dimpled) for it. Early in the spring. Also next week the splitter will be cut off
ID:	29844   Click image for larger version
Old 12-25-2020, 07:19 AM   #198 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Is this Brittish miles or English miles?
(I actually mean US or UK mpg)
Old 01-03-2021, 06:03 PM   #199 (permalink)
It is UK gallon measure, miles are the same. Making a 0w18 oil this week, I doubt the difference will be measureable
the car is much improved since then
Old 04-08-2021, 03:07 AM   #200 (permalink)
hey guys, (and gals if theres any cute ones). Just checking in, the buncemobile at the new digs and some tools I made from a new light material. It's similar to cf, slightly less flex modulus but lighter and higher mpa. I made a 1 inch square bracket for the bumper and it held in a flood. The oxalic acid helps ;0)
It's gonna get a proper respray in autumn and a dimpled roof then next year a flat floor and hopefully some cf and kevlar wheels. Will keep you posted you crazy cats!!
ID:	30389   Click image for larger version
ID:	30390   Click image for larger version
ID:	30391   Click image for larger version
ID:	30392   Click image for larger version
