Old 09-19-2012, 05:06 AM   #31 (permalink)
Looking good.
Did you sand it the whole way or start with a coping saw, or electric carving knife?
Old 09-19-2012, 06:33 AM   #32 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Nice project and good progress. Keep us posted!
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 09-19-2012, 09:37 AM   #33 (permalink)
This is a neat build. One thing about cab and beds, that I learned the hard way, is they move independently. The cab is usually mounted to the frame on a 4-6 molded rubber vibration isolators, and the bed solid. The problem is when you bridge the gap between bed and cab, things squeak. This might not sound like a big deal now, but I had a 1/4 'sleeper shell' mounted on one of my trucks that drove me insane, from rubbing and squeaking, until I remounted it, increasing the gap, using a flexible accordion boot to make the connection between the two.
Keep up the good work!
Old 09-19-2012, 10:16 AM   #34 (permalink)
90 day: 51.82 mpg (US)
This is coming along nicely!
* Will go ahead and start skinning this pretty soon. I want to see that it's actually going to work and look okay before I start purchasing materials for the rest of the work.
By "work" do you mean aerodynamically?
Once you get the top foam on and radius the transitions, any plans to do A-B-A testing? I see you have a ScanGauge
EDIT: I'm sure you're aware there's going to be negative pressure above the cap at speed; make sure you secure it well to the truck before driving. Hate to see all that work undone following a spectacular lift-off!
HHOTDI (12-13-2012)
Old 09-19-2012, 10:26 AM   #35 (permalink)
Originally Posted by a8ksh4 View Post
One of the design features that I haven't mentioned yet is that it's going to have a long recessed compartment on the driver side of the shell where I'll keep a fold out awning. :P
This is getting cooler and cooler!
I assume you mean a flush compartment with a door/panel to preserve good aerodynamics? I look at all the campers & RV's on the highway with all their exposed awnings & supports being blasted by the wind... and cringe a little.
Also, my pie in the sky idea at this point is to glue/clearcoat in a bunch of solar cells on the top similarly to how the all-electric race cars do... Need to see the light at the end of the tunnel before I really even think about this.
And that would be the cherry on top.
Added your build to the front page of the site.
Old 09-19-2012, 02:06 PM   #36 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Did I miss the post where you told what glue you are using? It looks like white bathroom caulking but I would like to know for sure. Thanks.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 09-19-2012, 11:31 PM   #37 (permalink)
B.O. Zen
Pickup - '99 Toyota Tacoma 2wd, Regular Cab, Short Bed
90 day: 34.62 mpg (US)
Yah, sanded all the way through.
I'm definately not sure how I'm going to mate this thing up to the cab... This feels like the most difficult part of the shell to cut/shape. I'm trying to cut it close... maybe 1/4" gap plus fiberglass, but I don't want it to rub/squeak. If I can find some long-lasting clear tape, I'll cover the paint on the cab where this thing is close and add a foam gasket to the shell that moves and seals.
@Metro... Yah, I'll have to do some ABA testing. I may be reluctant to change much at this point as long as it doesn't hurt my mileage, but I'm really hoping to see a few % improvement. By work, I mean that the aero is there and that I think I can make the finished product look quality.
The compartment/door would deff be flush and smooth. I have to see how ballsy I'm feeling before I'll cut this out of the side... I could mount the awning track on the outside of the shell w/o disrupting flow, as long as the awning bag wasn't hanging off of it, but then I have to think about where to store the bag when I'm not using it, etc... Hmm.
The glue is Loctite PL300 for Foamboard. It's water-soluble and feels like elmers glue, but with more bulk so it can be used to fill gaps.
The Following 2 Users Say Thank You to a8ksh4 For This Useful Post:
BamZipPow (09-02-2013), COcyclist (09-20-2012)
Old 09-19-2012, 11:45 PM   #38 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Heh hehe heh heh....He said " More bulk to fill the gaps!!"
Old 09-20-2012, 12:40 AM   #39 (permalink)
B.O. Zen
Looks like this foam will flex around a spherical shape just fine, so I'm going to take advantage of the ([edit]In best Bevis creepy laugh: "huh huh huh") tongue and groove and glue 2.25 of these panels butt to butt ("ah huh huh huh") for the top, ~9ft w/ overhang at the back.
Old 09-20-2012, 01:49 AM   #40 (permalink)
The Jetta - '13 Volkswagon Jetta SE
90 day: 37.38 mpg (US)
Interesting
