Old 08-25-2009, 07:31 PM   #21 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Lowe's, get treated 6x6 post and have them cut it down to several 2" sections for you. You can notch the tops of each piece, and they'll hold the car up fine.
Old 08-25-2009, 08:03 PM   #22 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Yes, I'd usually do that and borrow some from my dad but I'm not going to be under the car really so I figured I'd go with jackstands just to say time.
Anyone got any tricks from popping the LCA ball joints out of the knuckle? I've done it a bunch of times but it's not working for me now and the last thing I want to do is get violent and mess the whole thing up.
Old 08-25-2009, 08:07 PM   #23 (permalink)
Whoop's Wheels - '89 Honda Civic Wagovan
90 day: 39.09 mpg (US)
Ball joints out of the knuckle, yes. This is going to probably sound bad, but it works great and it doesn't cause any problems I have ever encountered.
Loosen, but do not remove the nut on the joint. Take a heavy sledge hammer, swing it as hard as you can and hit the side of the ball joint solidly. It usually takes 2-3 really heavy hits and then it decompresses just enough to let if fall loose.
Keep your personal knuckles out of the way.
The Following 2 Users Say Thank You to Whoops For This Useful Post:
Nden (02-05-2011), SVOboy (08-25-2009)
Old 08-25-2009, 08:10 PM   #24 (permalink)
Dartmouth 2010
SVOboy's Avatar
So hit the joint and not the LCA?
Old 08-25-2009, 10:18 PM   #25 (permalink)
Stick a 3' bar between the LCA and the radius rod, so that it goes over the LCA, then under the radius rod, from the back of the wheel. Hang a good amount of weight on it while you're hammering the sh!t out of the flat on the LCA (the spot you're already hitting). Also, if you have a propane torch and plan on replacing at least the boot, if not the ball joint, just go ahead and heat up the joint a bit, then hammer it.
PB blaster works well also.
Old 08-25-2009, 10:24 PM   #26 (permalink)
Dartmouth 2010
SVOboy's Avatar
I popped it last year, I'm not sure why it's being such a pain in the butt. We'll see in the morning.
In other news, tomorrow I'm buying a fairly new ford escape hybrid nimh battery pack!
Old 08-25-2009, 10:28 PM   #27 (permalink)
:O:O:O:O:O Lukky Baztid... :O:O:O:O:O
What's that gonna burn you for, if you don't mind me asking?
Old 08-25-2009, 10:29 PM   #28 (permalink)
Dartmouth 2010
SVOboy's Avatar
Hundred bucks!
Old 08-25-2009, 10:32 PM   #29 (permalink)
You suck. :P
What's the Ah rating on that pack?
Old 08-25-2009, 10:34 PM   #30 (permalink)
Dartmouth 2010
SVOboy's Avatar
Damned if I know, to be honest. It'll prolly sit around for a while until I figure out what to do with it
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Project: Dream CRX SVOboy EcoModding Central 118 09-19-2011 01:42 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
