Old 10-24-2021, 05:58 PM   #891 (permalink)
Gee, I wonder why you like this:
I like the bobbed platform of the Mini better. Maybe because I've got a small carport?
Old 10-26-2021, 10:45 PM   #892 (permalink)
Peugeot RCZ 1.6 THP 200 (2010)
https://www.ultimatespecs.com/car-co...ugeot-RCZ.html
Aerodynamic drag coefficient - Cx
0.322
Peugeot RCZ 156 THP (2009)
https://www.carinf.com/en/5d30418225.html
.............and the drag coefficient is 0.33.
First Test: 2012 Mini Coupe John Cooper Works
https://www.motortrend.com/reviews/2...ks-first-test/
An integrated roof spoiler set at the latter half of its contrasting "helmet" directs air down to an active rear spoiler that rises at 50 mph. Both provide 88 pounds of additional downforce while travelling at the Coupe's electronically limited 149 mph top speed. Having all that push to the ground has does have a negative effect, mostly in the form of a slightly higher drag coefficient that's up to 0.35 versus a slipperier 0.33 of the base Cooper hardtop. If you're wondering, no Coupe can be had with a color-matched helmet.
JCW The Differences: F56 JCW vs. Cooper S
https://www.northamericanmotoring.co...-cooper-s.html
*Aerodynamic Drag: Cooper S has a Cd of 0.31, frontal area of 2.09 square meters, for an effective total drag of 0.65 m^2. The JCW has a Cd or 0.34, same 2.09 m^2 frontal area, and a total drag of 0.71 m^2.
Not what I quite expected.
The boxy version of the Mini bests the Peugeot RCZ and the swoopy looking JWC Coupe Mini comes in last.
Yep - busted, but it does seem like at times that squeezing air may take more energy than it returns in favor of attached flow. I suppose that's why air-curtains for the front wheels are NOT a good DIY project. Roof slots don't seem as complex and may be more forgiving, at least in the case of my own roof wing/slotted cab extension.
freebeard (10-27-2021)
Old 10-30-2021, 01:56 PM   #893 (permalink)
An interesting mixture of aerodynamic and not:
Just A Car Guy: Have you heard about the Lamborghini Jumpacan? a bare 12-point roll cage shell salvaged, resurrected Lambo, with a Chevy LS motor, and off road tires
Old 10-30-2021, 06:08 PM   #894 (permalink)
Suddently the idea of an LS swap into a Lamborghini Urus makes a lot more sense. Unless a set of custom-built fairings could decrease the detrimental impact of that mod to the Huracán aerodinamically-wise.
Old 11-02-2021, 09:07 PM   #895 (permalink)
The windscreen frame of this cash-transit van and that narrower waistline caught my attention. Not aerodynamic at all, yet still seemingly more aerodynamic than the majority of cash-transit vans in Brazil.
Cd (04-09-2022)
Old 11-12-2021, 03:13 PM   #896 (permalink)
Sep 13th 2021
Tesla gets patent for laser beam windshield wipers, pew-pew
Lasers pointed in the direction of the driver, what could go wrong?
https://www.autoblog.com/2021/09/13/...shield-wipers/
It's important to note that just because Tesla has the patent doesn't mean it's going to use it. The company also has a patent for electromagnetic wipers. This system would involve an electromagnetic block moving past magnet bars embedded around the windshield to drag a single blade across the full expanse of the windshield, like a giant squeegee.
For its part, Tesla says the wind resistance created by traditional wipers' mechanical components decreases vehicle range. The electromagnetic wiper seems at least a little more realistic than laser beams, but either system would add significant cost and complexity to the car.
Old 11-13-2021, 10:08 AM   #897 (permalink)
The laser is only dangerous when you look at the leading circle of the beam and focus that.
looking at the sides means you are only seeing excited electrons falling back into orbit. Might be bad for pigeons flying above the car.
Old 11-14-2021, 06:21 PM   #898 (permalink)
http://justacarguy.blogspot.com/2021...r-show-or.html
Needs a grab rail on the light end as well.
Old 11-14-2021, 07:14 PM   #899 (permalink)
The Citroën C3 Pluriel, which was made only in Spain. I remember seeing a light-blue one in 2006, privately imported by a Citroën dealer in Florianópolis and featured on some local car shows.
freebeard (11-14-2021)
Old 11-16-2021, 07:13 AM   #900 (permalink)
Second comment is hilarious.
If you ever broke down in the desert, they'd never find you.
freebeard (11-16-2021)
