01-05-2011, 07:40 PM
#311 (permalink)
KITT: a workaround for the problem may be to use the "Post Reply" button rather than the "Quick Reply" box to avoid the "hang".
It appears to be a problem with FireFox & some of the AJAX code in vB. Sorting it out.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
01-05-2011, 07:41 PM
#312 (permalink)
ChrstphrR - thanks for the detailed info. Very helpful & I'm looking into this with the software support people.
01-07-2011, 03:05 AM
#313 (permalink)
Mechanical engineer
Quick reply button does not work properly. If I write a quick reply and push send this will send the message but it starts to download etc somethin and will never go back to original post.
I have to write ecomodder.com/forum if I want to see more...
I think it started doing that when I set up my signature was it last week :/.
I am using firefox.
01-07-2011, 03:09 AM
#314 (permalink)
Dartmouth 2010
As Darin already mentioned, the solution is to use Post Reply v. Quick Reply.
Firefox (only) has some issue and hangs at times. Hopefully a fix for this will come from whatever source, as it is a conflict between the forum code and Firefox and more or less out of our hands.
So, in conclusion:
- Use Post Reply
- Use Chrome
Sorry for the trouble!
01-07-2011, 01:09 PM
#315 (permalink)
ChrstphrR: RSS is fixed. Could you confirm it works for you? Thanks.
01-11-2011, 03:33 PM
#316 (permalink)
Yes, confirmed that it works now here - sorry, I'd been avoiding using the RSS reader for Ecomodder the last few days as my own little workaround.
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
01-22-2011, 08:44 PM
#317 (permalink)
OCD Master EcoModder
Originally Posted by MetroMPG
KITT: a workaround for the problem may be to use the "Post Reply" button rather than the "Quick Reply" box to avoid the "hang"...
Yeah. I use Firefox and have the same situation. I think it only hangs on "Quick Reply". "Quote" seems to take a while but I only tested that one time.
Coast long and prosper.
01-25-2011, 04:27 PM
#318 (permalink)
I believe the Firefox "quick reply" bug is now fixed.
If you guys (KITT, vekke, Bruce) would let me know if it's OK for you, I'd appreciate it.
01-25-2011, 04:48 PM
#319 (permalink)
NightKnight
Testing it out right now...
#320 (permalink)
NightKnight
Yep, works much, much better now!! Can you provide insight as to what the fix was?
Thank you!!!
