Old 07-31-2010, 12:36 PM   #101 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by robchalmers View Post
its allll plastic
well the bits I'll be spraying anyway
ah right.. No worries there then:-)
Is it worth trying to build the grill block into the grill seeing as you have it off already?
Old 07-31-2010, 01:49 PM   #102 (permalink)
The PRC.
Originally Posted by 320touring View Post
Prefered hothatch for 4wdrifting was the 205gti- liftoff oversteer FTW
Apologies for the Nova comment-although it seems to have dredged up some nostalgia
Have you got a route for the air intake? going to use the plastic bottles to make the grill block?
As for the painting- use paint, not primer so it doesnt absorb water and rust
Used to do my fwd 'drift' in a Mini, the original one. I got quite good at it on most roundabouts. But of course success leads you to become cocky and there was than incident with the dry stone wall in Lancashire and my mum's Mini City.
As for a block I'm off to copy this one
http://ecomodder.com/forum/showthrea...-pan-4492.html
Old 08-13-2010, 12:19 PM   #103 (permalink)
Team m8
Any startling developments on the polo front? I am eagerly anticipating some good mileage out this car!
my toyota should soon be due its second tank-if i've cracked 40mpg uk then you'll need to step it up boyo
Old 08-14-2010, 05:36 PM   #104 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
actually this time was a drop in FE.....
Not that big a shock when 200+ miles of return journey down the a49 from warrington to hereford for a race meet. at 5am its totally empty and just too tempting not to enjoy the secure road manors of the little 'dub within the legal speed limits.
still no mods though as I've been doing more and more writing for Radio Race Car International which has took up time...
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 08-14-2010, 06:59 PM   #105 (permalink)
Team m8
Poor show!
heh to be honest, the avensis does not lend itself to spirited driving..
Managed to eek out 40.1uk mpg of ths tank-i challenge you to reach 129% like i have
Old 08-18-2010, 03:51 PM   #106 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Rob, I used black foam pipe insulation stuffed between the VW grill bars for a quick, easy upper grill block. This is sold in the U.S. in hardware stores to insulate plumbing pipes. I thought I would try it temporarily to see if my Golf ran too hot because it is easily removed. It didn't overheat so it has stayed for 3 years. As others have stated, the diesel runs best when fully warmed up. In winter I split some pipe insulation to block off some of the bottom grill too. This helps the car warm up quicker. These engines are very efficient and don't heat up in winter like gasoline engines.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
robchalmers (08-20-2010)
Old 08-20-2010, 03:41 AM   #107 (permalink)
Diesel
Been meaning to get round to the grille block and that would be a great way to do it.
The polo' has got its next big test next week, when its being used a team bus on the way the Help for Heroes British 24hr, so it'll be doing a 300mile weekend with a full load of camping, race gear, pitboards and BBQ stuff
If anyone want to come and visit its at the teesside autodrome (ts6 6xh postcode) in Midddlesborough from the 27-29th
Karting | North East | Twin Kart | Go Karting
Old 08-20-2010, 08:01 AM   #108 (permalink)
Team m8
Sounds like you have quite the test planned for it!
I'm liking the pipe insulation for the grill block- effective and easy- nice one COcyclist
Old 08-20-2010, 05:26 PM   #109 (permalink)
The PRC.
In December we had our heating done and the gas people ordered about 2km too much insulation.
It sat in my garage.
Until last week.
Doh.
Good luck with the Karting.
The Following User Says Thank You to Arragonis For This Useful Post:
robchalmers (08-22-2010)
Old 08-21-2010, 08:54 PM   #110 (permalink)
Team m8
Until last week.
Doh.
ah bugger you'd have been there for ages to fill the fabia grill though
I'm confused re the grill block you're making-have you an intercooler to consider?
Reason i ask is my newly puchased saab has a large vent in the lower grill-but i dont want to block the intercooler?
VW Polo Cup game - Try to be economical master noxman The Lounge 3 04-12-2024 01:33 PM
Spark ignition Diesel engine, AKA your car mechman600 EcoModding Central 28 05-11-2017 07:12 PM
Undertray / belly pan build - VW Golf MK3 1.9 Turbo Diesel sallen Aerodynamics 27 05-21-2011 01:13 PM
Rob's '98 VW Polo Build Thread robchalmers EcoModding Central 36 05-16-2010 05:33 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
