Old 08-30-2012, 04:02 PM   #21 (permalink)
Originally Posted by Ultra-Orange View Post
...gets kinda wheezy about 40mph, handles hills well at sub 45 mph. Top end the motor really runs out of power.
I'd check the airfilter, pull it out and take it for a ride... um... drive? to see if top end speed increases. I'd replace the fuel filter, and check the fuel tank vent system, as well.
The Following User Says Thank You to metromizer For This Useful Post:
Ultra-Orange (08-31-2012)
Old 08-30-2012, 05:48 PM   #22 (permalink)
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
[IMG]Not sure on the HP, Just a honda gy6 150cc motor. initial acceleration is pretty snappy but gets kinda wheezy about 40mph, handles hills well at sub 45 mph. Top end the motor really runs out of power.
Found this: GY6 engine - Wikipedia, the free encyclopedia
Do the RPMs seem abnormally high for cruising above 40+? Wiki mentions its driven commonly with CV type carbs, this could be the reason why. CV carbs if not tuned properly could have demenishing performance results in the higher rpm range. luckily main jets are a snap to change out for better tunning
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
The Following User Says Thank You to RiderofBikes For This Useful Post:
Old 08-31-2012, 12:19 AM   #23 (permalink)
Fat free ranch for life!
Ultra-Orange's Avatar
Ecno-bubble - '96 Geo Metro Base
Air filter is an aftermarket foam thing im not excited about, Ill pull it off and see what happens. Changed the fuel filter already. Ill have to mess with the tank vent system.
It does seem to be rather high RPMs for the upper speed. I figured it was just the way the thing was geared. I opened up the carb once. its real simple and very basic.
Thanks for all the input!
Old 08-31-2012, 03:21 PM   #24 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
There is no miracle : a 160cc engine must be geared pretty low to tow this much weight.
The CVT is setted either towards acceleration or top end speed (which would be stupid with a hauling vehicle)
Your contribution brings back thoughts of a quad based low streamliner (and then I recall that the main advantage of my bike is lane splitting induced reliability of my commute time ...)
Old 09-07-2012, 02:28 PM   #25 (permalink)
quick update. Just small stuff for the moment. Need more choroplast and no way to haul it on the new rig
Enclosed the "Splashgaurds" and started to box in the lower cargo carrier.
Old 09-07-2012, 03:47 PM   #26 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
looking good!
To get more chloroplast, try taking a sheet and strapping it to the side of the trike?
Old 09-08-2012, 05:16 PM   #27 (permalink)
Finished boxing the rear cargo area.
Strengthened the "hatch" horizontally with Aluminum flatbar.
Secured it with Magnetic Cabinet latches.
The little metal pieces on the hatch (one on either side) don't fit flat against the magnetic catch so don't hold terribly well. Ill address this in future models.
She seems to have an easier time achieving/holding 45mph. Not sure if this is the result of boxing the tail, or more likely, from cleaning the carb. Haven't tried another Freeway/top speed run yet.
Want to address a wind buffeting issue first. Seems like wind is rushing around the narrow fairing and pushing me side to side. Not in a rush to close up the sides till I get the ride height down. This thing is tall and narrow. Unfortunately the wide cargo bay means lowering the ride height could cause lean angle issues. Beefing up the suspension will come first anyways.
Preloading the springs and thicker oil should help stiffen up the front end. Not sure what to do about the rear yet.
