Old 02-16-2012, 02:54 PM   #1 (permalink)
Elle - '10 Honda Element SC
slammed or hellaflush good for FE?
I just have to ask
is stuff like this good for FE? or is it like too much of a good thing?
this is all in fun but seriously. is this lower RR? throw some smooth wheel covers on.
is there something we are missing out on?
Old 02-16-2012, 03:32 PM   #2 (permalink)
The Bus is probably awesome but excess camber can't be good on the others. Tires rubbing on fenders can't help r.r.
Old 02-16-2012, 03:38 PM   #3 (permalink)
Okay, what the heck is RR? I know lower usually means better control, but that low seems extreme.
Old 02-16-2012, 03:42 PM   #4 (permalink)
rolling resistance
Old 02-16-2012, 04:04 PM   #5 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Look carefully at the sign, the car isn't modded, the occupants just ate too much!
Old 02-16-2012, 04:13 PM   #6 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Yeah, this guy !
HAhaha.
The Following User Says Thank You to CigaR007 For This Useful Post:
racerc2000 (02-16-2012)
Old 02-16-2012, 04:14 PM   #7 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Keep the tire camber under control and the tire inside the well. Lower is better for aerodynamics, but don't expect your "handling" to improve as suspension is designed to operate only within designed travel and angles. Exceed these and you will have less control than designed.
I'm not coasting, I'm shifting slowly.
Old 02-16-2012, 05:13 PM   #8 (permalink)
This, somewhat.
The effect of lowering on your suspension has a LOT to do with the geometry and type (Strut vs. double A-arm vs. straight axle, etc.) Cars with good geometry can be lowered a TON and still have very good handling (or better due to stiffer springs and lower CG).
But basically... lower = lower CdA, so its better for economy.
Old 02-16-2012, 05:16 PM   #9 (permalink)
Tire to fender and suspention contact is just going to add more drag.
Wearing the tire on its outer most edge is the oppisite of economical.
My engineer friend raised his 2000 sunfire by about 2 inches when he replaced the worn out struts on all 4 wheels. He said the effect was with in the standard devaition for his fuel economy, didn't see any difference at speed on his scan gauge 2 and said you wouldn't know anything had changed other than the smoother ride.
Lowing a car to where you are going to be beaten by the road surface just to pick up some MPGs isnt worth it.
Old 02-16-2012, 05:40 PM   #10 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Ditto!
On the FreshAlloy.com site, one of the Lowered 2006 M35 lost control in a curve going 35-40mph when another car got in the way.
He was very honest about the fact the the 30 series tires and lowering kit probably played a significate roll in the car leaving the road and flipping.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
