09-09-2022, 12:15 PM
#251 (permalink)
I was quoting the Timberline shingle video. I don't even have rafters in my roof.
.Two wrongs don't make a right, but three lefts do.
09-09-2022, 12:29 PM
#252 (permalink)
My panels are lagged into the rafters. I doubt code would allow panels to just be fixed to the sheeting. Heck, code wouldn't allow my parents to put panels on a manufactured home using any method.
09-09-2022, 12:32 PM
#253 (permalink)
Yes generally you can not connect mobile home solar to the power grid.
Unless the panels are ground mounted and have their own service drop.
09-09-2022, 04:32 PM
#254 (permalink)
AKA - Jason
That's weird considering you can connect a gas generator or car to the grid.
09-09-2022, 05:07 PM
#255 (permalink)
It's not the quality of power they are concerned with, but the integrity of the roof to hold more weight than it was designed for.
If I'm not mistaken, stick houses can re-roof over 1 layer of existing shingles, but not so on a mobile home. Old has to be torn off to keep weight down.
EDIT: It might not be the weight perse, but the lifting forces solar panels can generate that load the roof in a way they weren't designed.
09-10-2022, 07:51 AM
#256 (permalink)
County of Kern and so far Washoe have a 3 layer max on raftered roof with plywood sheeting. The limit on my manufactured home was to not exceed 60lb per sqft with 2 ft depth medium density snow. The inspector allowed a second layer of 50 year shingles.
I suspect most people bootleg their re-roof. My current house has a metal roof without associated permits so unless the structure fails..........
09-10-2022, 04:13 PM
#257 (permalink)
A mobile home and a mobile homes electrical connection are both ill suited to a solar install.
09-10-2022, 04:30 PM
#258 (permalink)
When all y'all talk about 'mobile home' I think Bolus Road Chief:
https://tinyhousetalk.com › bowlus-road-chief-vintage-travel-trailers
Bowlus Road Chief Vintage Travel Trailers - Tiny House Talk
on October 24, 2019 360 This is the Bowlus Road Chief Series of Vintage Travel Trailers. It's a very expensive but really awesome-looking vintage-style travel trailer. Currently, they have two models to choose from, the On The Road model which starts at $137,000, and the Endless Highways model which starts at $185,000.
09-10-2022, 07:30 PM
#259 (permalink)
How so? My parent's ground mount is wired directly into the panel that serves their home.
The top breaker is the solar connection.
09-11-2022, 08:59 AM
#260 (permalink)
Hmmm low voltage low temp rated wiring in a 220 box. What could go wrong?
