Old 02-13-2018, 08:47 AM   #271 (permalink)
Do you even BBCode?
Woah...Please see http://ecomodder.com/forum/showthrea...html#post78632
VehicleTeslaChevy BoltNissan Leaf
Capacity85 kWh60 kWh40 kWh
HP hours3,7402,6401,760
Weight1,200959560
Lbs HP Hr 10.52 11.9211.06
HP hr/lb3.125 2.753.14
Range265 239150
HP hr/mi 14.11 11.0411.73
Cost per mi4.36 3.343.35
Vehicle32 mpg Car18 mpg PU
Capacity590 kWh852 kWh
HP hours25,96037,488 HP hours
Weight113164 lbs
Lbs HP Hr.142.142 lbs
HP hr/lb229229 HP hr per lb
Range576468 miles
HP hr/mi45.0780.1 HP hrs per mi
Cost per mi7.1812.7 cents per mi
The Following 2 Users Say Thank You to Xist For This Useful Post:
freebeard (02-13-2018), redpoint5 (02-13-2018)
Old 02-13-2018, 12:44 PM   #272 (permalink)
Thanks. What had you reading a 10 -year-old thread anyway?
TestDrive's post at Permalink #20 is pretty impressive.
I consider this the most boring type of censorship.
The banality of ...white space.
Old 02-13-2018, 01:57 PM   #273 (permalink)
I honestly do not have any idea how I get where I am sometimes. I need an eye drive. Perhaps I had one, but I decided it was better to forget.
Why do people ask for how long I have had a memory problem?
UFO (02-13-2018)
Old 02-14-2018, 11:57 AM   #274 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
Can you just paste tab separated values here in the CODE tags?
Code:
	Col 1	Col 2	Col 3	Col 4
Row 1	11	12	13	14
Row 2	21	22	23	24
Row 3	31	32	33	34
Row 4	41	42	43	44
Edit: Yes, you can.
Old 02-14-2018, 01:37 PM   #275 (permalink)
Ford XLT Naked - '14 Ford F-150 XLT
90 day: 15.04 mpg (US)
Ford G-4 with Stinger - '14 Ford F-150 4X4 Super Crew XLT
90 day: 19.8 mpg (US)
Ford Stealth G-4 - '14 Ford F-150 4X4 Super Crew XLT
90 day: 10.47 mpg (US)
XLT Towing Keystone 5th wheel trailer - '14 Ford Keystone 5th Wheel XLT
90 day: 9.03 mpg (US)
Trip 2015 C Max Energi - '15 Ford C Max Energi SWP
90 day: 38.2 mpg (US)
Local 120 volt 2015 C-Max Energi - '15 Ford C-Max Energy SEL
90 day: 55.65 mpg (US)
Local 240 volt 2015 C-Max Energi - '15 Ford C Max Energi SLE
90 day: 57.63 mpg (US)
Energi Combined - '15 C Max Energi Leather
90 day: 51.2 mpg (US)
MoonDust for Travel - '19 Chevrolet Bolt LT
90 day: 123.11 mpg (US)
MoonDust 3 with 90% CE - '19 Chevy Bolt LT
90 day: 127.57 mpg (US)
Ecopia IV - '19 Chevy Bolt Lt
90 day: 126.39 mpg (US)
Ecopia IV Trip Log - '19 Chevy Bolt LT
90 day: 121.01 mpg (US)
Rate Rider Chevy Bolt - '19 Chevrolet Bolt LT-2
90 day: 123.16 mpg (US)
Teal Force One 70% - '24 Hyundai Ioniq 5 SEL
90 day: 98.52 mpg (US)
Teal Force Two 90% - '24 Hyundai Ioniq 5 SEL
90 day: 111.09 mpg (US)
Thanks, but i would have no clue how to use the function you just described. Could you copy and repost it formated for us?
Old 02-14-2018, 03:12 PM   #276 (permalink)
Thalmaturge
You just have ubb tags before/after your whole table like code and /code but with brackets around them (just like the quote tag) that give you a monospace font and spaces and tabs are maintained.
Then you can do what i did there and paste data straight from Excel/LibreOffice and it will come out as a table. Likewise copying a web table should go right in as a table too.
Code:
Vehicle	Tesla	Chevy Bolt	Nissan Leaf
Capacity	85 kWh	60 kWh	40 kWh
HP hours	3,740	2,640	1,760
Weight	1,200	959	560
Lbs HP Hr	10.52	11.92	11.06
HP hr/lb	3.125	2.75	3.14
Range	265	239	150
HP hr/mi	14.11	11.04	11.73
Cost per mi	4.36 	3.34	3.35
The only problem you'll run into is if a column has values that exceed the tab stop, data will run into the next column and things will get shuffled, as above.
Old 02-14-2018, 03:32 PM   #277 (permalink)
You can just use this: TheEnemy | Table Converter
freebeard (02-14-2018)
Old 02-16-2018, 12:47 PM   #278 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
Bloomberg is posting a Model 3 tracker. Up to 1,000/ week.
https://www.bloomberg.com/graphics/2018-tesla-tracker/
The Following 2 Users Say Thank You to sendler For This Useful Post:
RedDevil (02-16-2018), samwichse (02-16-2018)
Old 02-16-2018, 05:13 PM   #279 (permalink)
90 day: 55.9 mpg (US)
That tracker shows an interesting trend.
By each months end the number of Model 3's produced doubles.
If that trend persists for 30 years there will be more Model 3's than atoms in the entire universe.
(they'd surpass the total world car production within a year and a half)
freebeard (02-16-2018)
Old 02-18-2018, 10:28 AM   #280 (permalink)
Thalmaturge
In case it hasn't been posted here, the mix of materials in a model 3 body. Broken down into mild steel, high strength steel, ultra high strength steel, and aluminum.
https://electrek.co/2017/08/22/tesla...ody-alloy-mix/
Lots more pics in the article.
The Following 2 Users Say Thank You to samwichse For This Useful Post:
Daox (02-19-2018), NeilBlanchard (02-20-2018)
