Old 10-15-2012, 07:16 AM   #251 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by dipstick View Post
How are you going to replace the benefits of the water pump?
Can be replaced by electric, though was not yet brought up in this thread.
Many Hondas have their water pump gear-driven off an engine shaft so for those cars it would be more involved than just removing a belt.
Coast long and prosper.
Old 10-15-2012, 09:10 AM   #252 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I'm thinking... If water pump will be electric, and the water flow should be the same there's no point in this because power that mechanic pump will use will be less than electric. Due to alternator efficiency and the pump itself. Unless you're running deep cycle battery. Electric pump I presume should have some serious wattage so it's useless for any longer trip, because it will drain deep cycle battery to quickly.
It's not the best idea in my opinion to get rid off mechanic pump.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 10-15-2012, 10:09 AM   #253 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
But the pump's flow doesn't have to be the same, in fact most of the time it can be less, for example during warmup. Also, at higher engine rpms the water flow isn't greater, since the pump just starts cavitating, losing energy with no gains.
The speed of an electric pump can be regulated as needed - it depends on engine load & temperature, not rpms.
Old 10-15-2012, 10:41 AM   #254 (permalink)
I have a 55gpm pump on the diesel and it only draws 70 or 80 watts.
Old 10-15-2012, 04:30 PM   #255 (permalink)
AndrzejM's Avatar
I wasn't talking that flow have to be constant, I was saying that it should be similar to original flow.
I agree that electric pump has advantages over mechanical one, but I'm sure that factory, regardles of the car make spent enough money to do it right.
I can't agree that limited flow during warmup is a good idea though. It's best in my opinion to warm up engine as even as it's possible and limited flow works against it. I think that higher flow would be better to warm up engine more evenly.
That's less than I thought, thanks for sharing.
Old 10-15-2012, 10:04 PM   #256 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
the pump I plan to use will draw 6amps stock. I plan to cut that in half since its designed to cool a racing V8 sized engine.
but its rated for a continuous duty cycle which is what I need. I plan to cut power to it to "slow it down" quite a bit. once the pump is at the minimum needed speed the pump stops actually "doing" anything more. your thermostat takes over at that point opening and closing as needed.
what I would LOVE is to have a "clutch" on the main drive pulley so I can just push a button to "stop" the alternator and water pump all together without having to remove them. THAT would be ideal. then just push a button to re engage them. I could even make it automatic. every time I start the engine engage the clutch for say 60 second then turn it off. this way keeps things lubed and rust free etc..
Old 10-16-2012, 02:53 AM   #257 (permalink)
AndrzejM's Avatar
That can be done.
http://ecomodder.com/forum/showthrea...ing-14952.html
Old 10-16-2012, 06:35 PM   #258 (permalink)
Some times different approaches each have advantage. When it is Cold, you may want the engine to warm up Fast. If you park in the yard, a block heater might be good. But if you want to go Fast - Now! I used to have a VW Rabbit Diesel. As soon as the engine caught, I was riding the clutch. I was going to get Cold and Wet when I got to the Fire.
I have personally seen an answer to the water pump question. Teakettle. Put the radiator up Higher than the engine. Let the engine boil into the Radiator, and the condensate drop back into the engine. Saw this in 1930's Chevy? Guys were looking at it, and could not fine any water pump.
Keep It Simple Stupid. KISS
Old 10-16-2012, 06:47 PM   #259 (permalink)
Power steering delete - EcoModder
Its a P/S delete wiki with some info I added on P/S clutching.
Old 10-17-2012, 07:44 PM   #260 (permalink)
I disconnected the ps on the insight which is electric and gained 3 mpg. It wasnt too much difficult to steer than before.
As for water, you dont want to do that as it will generate hot spots and maybe even stress. Frankly, not sure you can guess when it should be off or on.
An insight owner did away with his mechanic pump for water and used a solar hot water one on electric. It ran at a lower volume and I understand it worked well with the cooling system and antifreeze in it.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Kawasaki starts promoting its bikes' MPG ratings - best = 70 mpg MetroMPG Motorcycles / Scooters 35 09-09-2010 11:41 PM
Truck Trend claims 10% more MPG with K&N in 2009 Ford F-150 after bogus road test MetroMPG EcoModding Central 102 12-16-2009 06:45 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
