03-30-2016, 02:14 PM
Turbo as a charger?
So after viewing the Mercedes F1 Split Turbo explanation video I've had an idea...
Why couldn't we use turbos to charge an electrical system similar to an alternator? Instead of have it belt driven, attach the alternator to the shaft of the turbine...?
Would this even be possible? Or would it generate enough electrical charge?
03-30-2016, 02:34 PM
I think someone mentioned this idea recently and the answer is that turbos spin far faster than alternators, so much so that it would not work.
03-30-2016, 02:48 PM
I'd be interested in figuring out a way around that...
Turbos spin at 80,000 - 200,000 rpm, right? And an alternator spins at about 1/50th that speed?
So wouldn't we just need some way of stepping down the speed of the input to the alternator?
03-30-2016, 03:14 PM
Those step down gear boxes are expensive and the ones I know of are only approved for 40,000 to 50,000 RPM. Most are only used for around half of that.
This system would be so expensive there wouldn't be any point.
03-30-2016, 06:33 PM
EcoModding flying lizard
How about turning the turbocharger into the generator/alternator. Make the magnets part of the turbine and have the windings inside the turbo?
But I have seen threads like this before, unless a major manufacturer gets involved I don't think this is going anywhere.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
Originally Posted by MetroMPG
You can lead a fashion-conscious horse to unusual-looking water...
03-30-2016, 06:55 PM
IIRC the electric power supply for modern jet aircraft is supplied from a similar setup.
03-30-2016, 07:18 PM
Master Novice
Eh, just mount the magnets directly to the shaft and pickup coils around them. Voltage would be sky-high but feed it through a transformer to jack the amps up and there you are.
I've fantasized about replacing the distro in my pickup with a racing-style magneto-distributor, which really would make the truck my go-to zombie apocalypse choice. Take out the ignition duties and replace all your lights with LEDs and the alternator doesn't have nearly as much to do.
Of course as I said, it's a fantasy.
[edit]
Oops, I see Daschicken (?) has beaten me to it.
03-30-2016, 07:43 PM
03-30-2016, 08:16 PM
#9 (permalink)
I still consider a magneto the best setup for spark-ignition. No wonder they're still prevalent in piston-engined light aircraft and even in some motorcycles. BTW you might remember that some off-road motorcycles, even when fitted with EFI and some weak headlight, don't even have a battery and rely only in the electricity supplied by the magneto. Sure you wouldn't wanna get rid of the battery in your truck because of the starter, but anyway, a magneto is a reasonable option.
04-01-2016, 02:39 PM
#10 (permalink)
Plausible
Not true any more.
Brushless DC Motors, Servo Motors, DC Motors, Permenant Magnet AC Motors, AC Servo Motors, Permanent Magnet Synchronous Motors, High Speed Motors, Custom Motors, Gearheads, Encoders, Motion Control, Slotless Motors, Sensorless, Ironless Motors, Vacuu
has this
http://www.koford.com/Generators.pdf[/COLOR]
This is rated up to 400,000 rpm
If you use a waste gate housing you can regulat the shaft Speed. Or even better a VGT (Verible Geometry Turbine )
"Oil pan 4 Those step down gear boxes are expensive and the ones I know of are only approved for 40,000 to 50,000 RPM. Most are only used for around half of that.
This system would be so expensive there wouldn't be any point."
With the gen set parts in the link, the need for a gear box removed ,is this posable?
As for expensive all R&D is. The key is to use off the shelf parts.
My thoughts add 2nd turbocharger ,my rig already has1. Maby a vgt turbo link . Replace the impeller (as it is the thrust bearing pre load) with a spacer and direct cupple the BLDC400, 000 rpm motor/gen to the shaft.
The reason for wanting this not to be in my Intake sys., is simple. Any failure bits and pices would go through the engine, resulting in $1000s of damage. Develop and prove the sys. before putting it on the primary turbo. Also on the primary it would increase lag. And the rule of 1/3. You can recover 1/3 of the waste energy per stage. Eg 160hp into the turbo 120hp bown the pipe and 40hp at the shaft
Gumby stay flexible.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
