04-16-2013, 05:08 PM
Wiper motor = adjustable grill block motor?
I just removed my rear wiper assembly for aerodynamic purposes. The motor that came out of it is pretty durable and has plenty of torque. Could this be used for an adjustable grill block?
I don't know how it actually works, or if there is a simple way to make it adjustable, or somehow switch it to full left or full right at will.
I try to be helpful. I'm not an expert.
The Following User Says Thank You to sheepdog 44 For This Useful Post:
04-16-2013, 07:50 PM
At least it will be closed half the time. :-)
04-16-2013, 08:31 PM
Usual wiper motors I saw are just a rotary motor with some levers that turns a single rotational motion into the back and forth motion. Yet you could still maintain the levers - using a potentiometer to determine the position... I would think a relay to turn it on/off, some way to turn the relay off when it's in a given position (I forget my electronics, just a way to compare the voltage from the potentiometer to some preset start and stop figures, when it goes above, or drops below something it shuts the relay off), and a pushbutton switch to force it to ignore the previous circuit - you'd just hold it for like 1/3 of a second or something to start it moving, and it should auto shut off when it finishes a stroke for instance. It's that or have another switch in each position so when it makes contact it does the same though the switches might wear out faster than the potentiometer being flicked open/closed many times per day. (assuming based on the need for cooling this would be the norm)
04-17-2013, 09:28 PM
eco....something or other
You would have better luck with a linear actuator. You could even turn your wiper motor into one by putting threaded rod on the shaft and then putting a nut on your grille block. Run it forward and reverse to open and close it.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
04-18-2013, 05:25 AM
Scandinavian creature
Or get a cheap door-lock actuator instead
The Following User Says Thank You to Quezacotl For This Useful Post:
04-18-2013, 09:05 AM
OCD Master EcoModder
Hmmm...
A door lock actuator might work well with the output shaft coupled to a threaded rod as IsaacCarlson suggested. Normally the actuator throws its full length and then stops, but the threaded rod plus a momentary contact switch might give the control you need.
Coast long and prosper.
04-18-2013, 03:20 PM
What about R/C model equipment? Lots of controllable and switchable stuff on low voltage feed there, never mind that the car we want it for is scale 1/1.
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
Cd (09-02-2013), Cobb (04-18-2013) |
04-18-2013, 06:04 PM
Originally Posted by IsaacCarlson
...You could even turn your wiper motor into [a linear actuator] by putting threaded rod on the shaft and then putting a nut on your grille block. Run it forward and reverse to open and close it.
Most wiper motors are not designed to run backwards.
The wiper motors that I have the most experience with are out of older aircooled Porsches. They have microswitches built into the output linkage that tells the motor where the "park" position is. If the microswitch gets closed and the wiper stalk is in the "do not run" position, the relay running the motor gets switched off. If either of those things is not true, the relay keeps sending power to the motor.
-soD
04-18-2013, 06:45 PM
#9 (permalink)
I played with one from a vw rabbit of the 80s to make a sex machine. The polarity was reversed for slow vs fast mode as the brushes were offset. The crank just spun in circles and the levers made the wipers worked. If you used a draw slide with a pivot point to the crank you got a rod that goes in and out and can attach your favorite adult toy to.
Sheep, are you doing it right? Myself, JimE and a few others have like 99% of our grills blocked off on our insights and heat isnt an issue. Running the ac I see 184 degrees where as the coolant relay doesnt click til 202 degrees F. Without ac I see 177-179 degrees.
I like the door lock solonoid idea. Make 2 pieces of coloroplast with slots that are misaligned. This way in one orientation a block is achieved. Then within a half or inch movement the slots like you and its OPEN. Mount this to the grill or behind the grill depending on if you are trying to help aero or cooling and then rig up a switch or something to the solenoid.
The other idea is to use a servo and radio from a rc car that allows minute adjustments in movement and use it to slowly open or close something nad to what degree.
-soD
04-20-2013, 12:08 PM
#10 (permalink)
Neutral is my favorite
Power Antenna? I have one laying around for my Grand Marquis. It's goes back and forth.
Just saying...
-ryan s.
1997 Ford Crown Victoria HPP- "Tank of Justice III" 194k - 578.9 miles on ONE tank
2003 Mercury Marauder- 63k, not so fuel efficient; #1,548 of 11,052
2008 Lincoln Navigator L - 244k (don't ask about mpg)
The Following User Says Thank You to svt98t For This Useful Post:
