Old 08-27-2009, 04:40 PM   #271 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Originally Posted by bennelson View Post
You know you're an Ecomodder when This:
Turns you on more than This:
YKYAEMI: You see this picture and go "NNOOOOOO Bucket headlights ! Get some Lexan quick, i can feel the drag from here.......
Old 08-31-2009, 08:29 AM   #272 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
YKYEM...
...when looking for a new car you pay less attention to how efficient it is and more to how efficient you can make it.
Old 09-02-2009, 12:28 AM   #273 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
Probably a repeat:
YKYEM when:
No one at work asks you to drive to lunch any more. They know you've removed the passanger seat and back seat.
Old 09-02-2009, 10:59 AM   #274 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
The picture says all...
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 09-02-2009, 03:07 PM   #275 (permalink)
aero guerrilla
Piwoslaw's Avatar
Oh, are those your new toys, Denis?
Old 09-02-2009, 03:26 PM   #276 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Classic half-arse HAM setup, but with probably $15,000 worth of equipment, easy!
Not sure why you would need 2 cross-band repeater radios unless the vehicle is a mobile repeater "tower" or command center.
But ya gotta admit -- it's all within reach of the driver
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 09-02-2009, 05:07 PM   #277 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 39.05 mpg (US)
You guys and your stuff...
Old 09-02-2009, 06:36 PM   #278 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
kindly explain what everythings for
Past Present Future?
Old 09-02-2009, 07:56 PM   #279 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
I'll do my best -- clockwise around the Steering Wheel:
-On the Wheel: handheld HAM walkie
-TTY/Tune box (black with red X): likely receives radio text transmissions and converts it to readable print, it may run off of the radio unit above that, which is a high-end HAM radio.
-Above that is a sqaure speaker (just to the right is another handheld radio)
-Another high-end HAM radio identical to the one hooked to the TTY
-The grey unit is a "Cross-Band" repeater radio. Using a radio outside of the vehicle, the input is boosted to another frequency. Popular with the handheld (in this case the input is 144.390 MHz, output is 146.625 -- popular for use with the handheld unit on the wheel, if outside the car).
-At the top is a scanner or high-end CB radio
-To the right of that is a radar detector -- now we're getting somewhere
-3 more Cross-Band HAM radios (down to the righter-most part of the wheel) -- these can also be used to transmit on one frequency, press a button, and quickly transmit on the other frequency. (How does 1 person do all of this ???). They also might transmit other data. Expensive choice, though.
-Bottom Right: 2 types of mobile phones (one looks to be a satellite phone, maybe).
Dashboard / Speedometer Area:
Yellow/White boxes = speakers.
Red push buttons likely control speaker input
Dash-Top:
-Another Scanner
-Some sort of huge device is next to that (need help with that one) -- it could receive and transmit TV signals over HAM bands).
Passenger Seat:
-Just above the gray phone is a real-time radar screen
-With another one just barely in view to the right of that
Other Observations:
- The vehicle is Red with yellow lights in the hood -- this stuff generates a LOT of heat and draws Amps like crazy, so the engine has to be running and probably has a heavy-duty alternator -- the hood probably has to be up when it's all running and stationary, which would make the yellow lights visible. I thought it might be a County Mobile Command Center, but the radar detector says more like "storm chaser"
- Out of view is likely a laptop computer
I personally have 3 of these items that are a 1-tenth the value of any of this stuff: a 10 year-old mobile radio like above the "Red-X", a cheapo CB and a mobile walkie like what's stuck to the wheel. They're all mounted to a board with a handle, so I can pick it up, move it to another vehicle, and belt it in.
This is a bit overboard. I would mount everything in a tower to the right of the driver, or get a van and some friends to help out!
RH77
_
_
The Following User Says Thank You to RH77 For This Useful Post:
JacobAziza (09-02-2009)
Old 09-02-2009, 08:42 PM   #280 (permalink)
order99's Avatar
There's something missing in that picture...
Oh yes-a windshield. I'm assuming that's just a trick of the camera angle, right?
Ecomodder in the Philadelphia Inquirer ericbecky EcoModding Central 10 11-22-2012 01:14 PM
Official EcoModder ScanGauge II group buy info MetroMPG Instrumentation 71 03-30-2010 07:48 PM
Ecomodder EV meetup bennelson Fossil Fuel Free 1 04-20-2008 10:57 PM
Hybridfest guy now at ecomodder ericbecky Introductions 9 03-21-2008 11:43 AM
Ecomodder and others RSS feeds NoCO2 Forum News & Feedback 4 02-21-2008 02:18 PM
