09-02-2013, 04:47 PM
#31 (permalink)
Using MPGuino for diesel instrumentation and metric conversion
Dear Andrzej,
Ok to all. I realized that it is just a constant to be changed, so no need to modify code. Of course!
Clear.
I sent images of the MPguino I have, and of a kind of a TinyGuino I already have. Did you see them?
I need to remember from where in the US I got it to get the parts. It came with some parts included, maybe it use only these.
Do you refer to this Arduido specimen or to another one?
My car is at the garage by now, for a Little stretching of chassis.
Best,
Oldbeaver
Mercedes 300 D turbo 1993
09-03-2013, 03:04 AM
#32 (permalink)
Yes I saw those pics. You can use that TinyGuino for a conversion unit, of course. But ATTiny is a single chip that can do the same.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
09-03-2013, 10:19 AM
#33 (permalink)
ATtiny chip for simple conversions
Do you mean something like this?:
When I searched for ATtiny microchip, there showed several versions, small and bigger. For what I can see, you can solder it in any exp board and, yes, put it everywhere.
Two questions:
First: normally Arduino boards and these small chips use 5VDC or even less. How do we get that voltage from the 12 to 14 VDC of the car? I used a voltage divisor or such, with two resistors.
Second: how do we take the analog signals of the car (normally 0-12V) to input them in MPguino and ATmini without a) burn the microprocessor, b) alter the car parameters?
I am weak in electronic knowledge, just able to solder kits and circuits made by others and that is it.
Oldbeaver
Reason: Improving
09-03-2013, 04:01 PM
#34 (permalink)
Jose,
Take a look here: MPGuino - EcoModder
You'll find answer to both of your questions. First answer is 7805 voltage stabilizer, second answer is 50k resistor and 5,1V Zener diode. But that's for measuring pulses. For analog signals you need a voltage divider made of two resistors.
And regarding ATTiny there are many versions of the chip and we'll find the right one for the task.
09-03-2013, 05:47 PM
#35 (permalink)
Customizing instrumentation for a diesel .
Jose,
Ok, so we will customize an instrumentation solution for a 1993 Mercedes Diesel, with the help of MPGuino and some versión of ATTiny. If we succeed, at least many Mercedes diesel cars may benefit of it, starting with mine. Excellent! Thank you for sharing yr knowledge.
OldBeaver
09-17-2013, 12:51 PM
#36 (permalink)
Mercedes Diesel ready to start the project
Dear AndrzejM and all Forum guys,
At last, I have my car back home from the garaje, after some painting, radiator repair, change of cooling fan, some body work, passenger seat command repair and several other parts replacements, such as thermostat, wáter pump, and many others.
Step forward:
First, I think the first to do is to identifiy the necessary signals spots to get them, and have them available for use in the Project. Any ideas on a good place and holder of the signal wires ends, hardware to use, and such? I can deliver the signals to inside the cabin or leave them under the Bonnet.
Second, construct a small board where I can solder the zener, the voltaje regulator, the voltaje dividers, and so on. Maybe some led maybe useful to see if there are signals coming. Leave space for the ATtiny. I think it may be soldered here.
Third, have some kind of signal sensor to check before input signals to MPGuino.
Fourth: Install MPGuino, power it and get signals to input it. Callibrate in the car.
I am almost sure I saw some small circuits as to test signals. Not necessary an Oscilloscope.
Andrzej: please give some advice about the hardware to buy, and the circuit scheme, to start building.
Attached are some pictures of the sensors where I plan to get the signals for the Project. There is a picture of the car also.
Looking forward to yr comments and advice,
OldBeaver
Reason: Improving
09-18-2013, 04:19 PM
#37 (permalink)
Jose,
I think that the best way is to get all signals from ECU harness.
Regarding hardware that you need to buy, first of all you need zener diodes, resistors and working MPGuino. And it doesn't matter which version of the code you have.
Definitely scope would be handy to see what's going on between ECU and injection pump.
09-19-2013, 11:10 AM
#38 (permalink)
Connecting to diesel injection signals.
Jose,
Ok, I will locate the ECU, make the connections and borrow a scope from someone to start testing.
First, I need to locate diesel ECU,
I think I have a working MPGuino which I may test connecting VSS signal and rpm signal, besides the power and zener diodes. Anyway, the MPGuino I have has its own zeners, and wants 12V input, from what I recall. This will be ok for testing.
I need to prepare a cable and plug to bring signals to MPGuino.
Will take pictures to share with the Forum.
OldBeaver
09-20-2013, 03:02 AM
#39 (permalink)
You're right... You don't need zeners and resistors for MPGuino... I forgot, because I have it build on my own from Arduino Uno. As soon as you locate all signals we need we'll think of converting signals to pulses compatible with MPGuino.
09-20-2013, 10:10 AM
#40 (permalink)
Getting signals
I think I will not touch the ECU harness at all. Instead, I will get the signals from several harnesses that are almost all identified.
Now I am trying to identify the precise wire based on the color. However, the color code abbreviations I have do not match the ones in the circuits. The ones I have are:
BK black
BR Brown
BU Blue
IV Ivory
GN Green
GY Gray
TR Neutral transparent
OR Orange
PK Pink
RD Red
VI Violet
WT White
YL Yellow
Please see the circuit of the Mercedes diesel injection systems I am sending by email due to its size, and you will realize they are using different color abbreviations.
If you can help me with that it will be nice.
Last minute: these are the German abbreviations for collors, as was pointed to me by AndrzejM. American Mercedes Manuals use a three letter abbreviations, well known for anyone.
Oldbeaver
Reason: Got answer
