Old 06-17-2013, 05:06 AM   #21 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
check the plugs to track rich running.
Could be jets, could be CV carbs diaphragm.
what was your ride like ?
dragster at the light or cruising gently on the highway ?
Old 06-18-2013, 02:00 AM   #22 (permalink)
I'm thinking of a manifold and one old VW carb to feed that 'Wing.
I recently saw a motorcycle fitted with an actual VW engine.
Old 06-18-2013, 03:31 AM   #23 (permalink)
I remember when Cycle World reviewed those back in the '80s. It was not a flattering review until they put a hot rod VW engine in it but still, I want one.
Old 06-18-2013, 11:03 AM   #24 (permalink)
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
The v65 was NOT known for reasonable fuel economy.
Also, when you have a month of sundays check the valve clearances. Since they are among the most difficult (or expensive) to adjust in motorcycledom it may not have ever been done.
Heh. I just did the opposite. Out went the big bike, now have a $160 250cc. I'm sure I'll eventually right size to a 650 or 700 some day.
Good design is simple. Getting there isn't.
Old 06-18-2013, 11:04 AM   #25 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
Yes, the brazillian boss hoss Though I'm sure Germany could hook them up with fuel injection(that runs on ethanol even)
Old 06-18-2013, 11:10 AM   #26 (permalink)
P-hack's Avatar
re: 250, the buyer just picked it up last night, I took it for a ride. It handles great, but wow does it seem slow now.
I've got a wideband o2 sensor on order and have been reading up on carb theory and procedures and jet kits, maybe if I set the main jet 13:1 and the rest to ~15:1 I will get a mostly tame bike until you open it up all the way and see if it is manageable (and what the mpg effect is). There is even a dyno 9 miles away it turns out.
I've a kevlar clutch and spring on order, so I can afford to slip the clutch a bit when higher rpm power band is "needed", and can entertain exhaust and airbox mods as well (not for efficiency). It still needs to be a monster, but maybe low rpm and cruising mpg don't have to suffer.
Old 06-20-2013, 11:04 PM   #27 (permalink)
P-hack's Avatar
So after a 27mpg tank, I have been P&Ging a lot more, getting used to bump starting the slipper clutch, but the whole thing is starting to slip so hoping my kevlar gets here soon, stupid store didn't actually have a new clutch spring.
A couple observations:
This thing is a LOT of fun to pulse.
It glides better than any other bike I've owned with the clutch in (yes I see the oiling diagram that has the transmission shafts fed by the pump). Heavy. I wonder if only half the plates are dragging because of the slipper sprag.
My left hand hurts.
Also the tires were low so I pumped them up to 35/40.
Old 06-24-2013, 04:47 AM   #28 (permalink)
Altough the Amazonas uses a way smaller engine than the Boss Hoss, it's incredibly heavy. Well, retrofitting EFI wouldn't be so hard, considering that an MPFI setup was factory-fitted in the Mexican Beetle and the Brazilian Kombi, there were even some dedicated-ethanol versions. It would also be better to get MPFI instead of TBI while running on ethanol, to avoid the intake manifold to freeze and eventually get choked with built-up ice.
