Originally Posted by pete c
I think it comes down to RVers having already numbed themselves concerning the topic of mileage. I mean, you have to, to drive around in a barge getting 6 mpg. Any attempt to bring them out of the fog is met with the same reaction you get from a junkie when you want to take his fix away.
Same goes with the bigfoot wannabe 17 year olds in their lifted rangers.
I do think that there is a correlation between "being able to afford it" (means FE is irrelevant) and the few years most will use them (maybe 6-10 at the outside). Still, if one collected the number of threads that have an interest in FE in the title
it is not a small number. I hate to think there is a culture of enforced stupidity, but it would appear so . . as if throwing money away needlessly means one is "rich".
Frankly, most do not travel all that much. 5k annually for families (say over a decade), up to maybe 15k annually for retirees (under a decade).
Still, this does
not include those who have moved from the stick & brick house to a mobile home (in the truest sense of that term) which allows them to pursue opportunity cross-continent at a low long-term cost. This is a growing segment (tens of thousands; possibly hundreds).
The annual per person energy consumption has to be compared to other sorts of housing, or housing arrangements for a fuller picture to emerge.
In another example, if one specs an aero lightweight trailer, then one is not forced to use a pickup for full-time use. The best vehicle that suits ones solo miles
that can also tow a travel trailer is far wider than most assume (practically, one can name the car, from Mini Cooper to minivan to sedan). This is resisted on assumptions not tested . . much less in keeping with what was done from the 1950's to the 1980s when cars became underpowered for this job, and trailers (even the aero ones) got heavier.
To end this, the usual gas powered pickup pulling a sqaure white box at 8-11 mpg (a general norm) meets up with a Euro turbodiesel pulling an aluminum aero trailer at 21-25 mpg (a rare, but possible mark). Initial purchase price is one thing on brand new, but the market is full of used for the savvy buyer.
