Old 07-20-2015, 09:32 PM   #591 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
glad you are working out the bugs instead of throwing in the towel.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
BamZipPow (07-20-2015)
Old 07-21-2015, 01:31 PM   #592 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
As much fun as I'm having with this project...no way!
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (07-22-2015)
Old 07-21-2015, 01:39 PM   #593 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Unhappy
Tore down the wheel assembly so I can take it to the welder to have them flatten it back straight and weld up some supports on the bottom side of the support plate. The hub assembly is supposed to be pointing straight up.
Old 07-22-2015, 03:51 PM   #594 (permalink)
straight up
There once was a man from College Station,
who had the lowest drag trailer in the nation.
But torque grabbed his steel,
and tweaked the angle of his wheel,
now the welder's gonna see if he can make it heal!
The Following 6 Users Say Thank You to aerohead For This Useful Post:
BamZipPow (07-22-2015), deejaaa (07-22-2015), Fat Charlie (07-22-2015), jeff88 (07-23-2015), MetroMPG (07-22-2015), Xist (07-23-2015)
Old 07-22-2015, 04:31 PM   #595 (permalink)
90 day: 51.82 mpg (US)
This is what keeps me coming to EcoModder.
Old 07-22-2015, 04:32 PM   #596 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Now the welder's got to stop this abrasion?
Transmission type Efficiency
The Following 3 Users Say Thank You to Fat Charlie For This Useful Post:
aerohead (07-22-2015), BamZipPow (07-22-2015), deejaaa (07-22-2015)
Old 07-22-2015, 08:36 PM   #597 (permalink)
flexation
The Following 3 Users Say Thank You to Ardent For This Useful Post:
aerohead (07-24-2015), BamZipPow (07-23-2015), Fat Charlie (07-24-2015)
Old 07-23-2015, 06:16 PM   #598 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Got the phone call this morning that my support plate was done!
The support plate looked good and I got it painted before I started my re-assembly.
I now have the proper clearance from the Coroplast floor!
I decided not to make things overly complicated by trying to move things around so I kept the air bag spring in the front to maximize the spring capacity since the support plate is reinforced with stiffening plates. I did remove the air gauge as it's really not needed and the stiffening plates will provide some protection to the air valve.
I am considering adding a shock absorber by attaching it from one side of the wheel axle to one of the stiffening plates near the front. I'll have to see if one from a motorcycle or scooter will work or not.
Looks like I'll git to test the improved setup on the trip out to Gonzales, TX.
Old 07-23-2015, 06:29 PM   #599 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Originally Posted by Ardent View Post
flexation
Yes...the welder hopefully got this issue under control with the stiffening plates. Flexation is a $68 word now..
Old 07-23-2015, 07:58 PM   #600 (permalink)
Not banned yet
deejaaa's Avatar
looks HD now. should hold up to the pounding it's obviously taken. funny, when building something, the ugly heads that rear to let you know: you don't have it figured out yet.
i will be in Canada for 3 weeks so i won't be responding anymore after Sat. hope to have a good time visiting in-laws so will catch up upon my return.
