Old 03-26-2013, 09:05 PM   #1 (permalink)
calculating mpg without a SG
Is using my low fuel warning light a pretty reliable starting/stopping place for calculations? I know I need a SG but not now. p.s. wouldn't you want to use different pumps so inaccurate pumps would tend to equal out?
Old 03-26-2013, 09:20 PM   #2 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
If you can, using the same pump would be more reliable. Even if the pump is slightly off, it will be consistent and better for collecting data.
Edit: Using the gas light will be relatively consistent, but if you fill up earlier or later than it, it won't affect MPG, just distance traveled.
Old 03-28-2013, 08:34 AM   #3 (permalink)
Grey - '01 Hyundai Accent GL
90 day: 35.55 mpg (US)
Big Red - '06 Mitsubishi Eclipse GS
90 day: 31.57 mpg (US)
Roller-Skate - '86 Pontiac Fiero
I have been accused of being obtuse in the past, so I won't be offended if it happens again. I am not sure of your question. If you are NOT filling the tank there is no easy, reliable way to estimate MPG, without instrumentation. This thread has a good explanation: http://ecomodder.com/forum/showthrea...ill-25263.html
Dan
Old 03-28-2013, 11:05 AM   #4 (permalink)
got it thanks guys
Old 03-28-2013, 02:48 PM   #5 (permalink)
90 day: 51.82 mpg (US)
See also: http://ecomodder.com/forum/showthrea...rmula-352.html
Old 03-28-2013, 03:07 PM   #6 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Even the low fuel light can be inconsistent. I've seen it come on a gallon early when parked facing uphill.
Old 03-28-2013, 05:02 PM   #7 (permalink)
ok so you are saying the MOST accurate start/stop point is a full tank. that makes sense.
Old 03-28-2013, 05:15 PM   #8 (permalink)
90 day: 56.53 mpg (US)
I've postponed filling up the Pan (long before it became a Rat) because the fuel warning light did come on but went off again, adding mile after mile reassured that even when it would stay on I'd still have another gallon to find a pump.
Had to push it the last mile to the next pump...
