Old 01-27-2009, 02:16 PM   #11 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
Well I have no idea, but to be devil's advocate...if the manual causes 15% losses and the auto causes 17% losses, that is much more than "2% less efficient." The losses are in fact (.17/.15 - 1 = .13) 13% greater.
Old 01-27-2009, 03:10 PM   #12 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Originally Posted by dcb View Post
Do you have a source for this? Anytime the converter isn't locked up there are hydrodynamic losses.
This lists the automatic as %5 to %15 less efficient (not %1 to %2):
http://en.wikipedia.org/wiki/Manual_transmission#Benefits
Some automatics do lock the converter in every gear now, some don't of course. Its hard to generalize these days about transmissions, so many variations now.
Back to the original question, it would be good to have an oil pressure gauge so you could see how oil pressure varies with rpm, or even using very light oil like 0W20. Since most cars don't have one I imagine most cars are pretty safe using 1/2 throttle or less at any rpm over idle speed.
Ian
Old 01-27-2009, 03:52 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Fair Enough KJSats
I did learn from this discussion that aside from bucking (I think we all agree that a bucking engine is bad), there is a minimum rpm for adequate bearing oil coverage.
I do not have specific values for specific vehicles, but this diagrams the general idea:
Oil analysis and lubrication learning cennter
"This condition is represented by the equation ZN/P, where Z = viscosity, N = speed (rpm) and P = load.
Old 01-27-2009, 04:16 PM   #14 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The numbers weren't accurate to begin with.. there is no fixed percentage of losses that can occur through a given type of drivetrain, so the numbers were placed there as holders to show the actual point - that automatic transmissions are no longer the power-defeating POS's they used to be.
I thought this would be evidenced by the use of words like "assumed" and "something like".
Sorry for not making that clear.
Old 01-27-2009, 04:39 PM   #15 (permalink)
dcb
needs more cowbell
dcb's Avatar
Well, folks go to great lengths for a %5-%15 improvement, so I'm not ready not rule out POS just yet
Old 01-27-2009, 07:37 PM   #16 (permalink)
Remember, that drivetrain loss is frictional/heat loss... it's not linear. It's an accepted average.
In fact, the losses multiply as speed increases, almost parallel to speed.
Anyway - the point was that automatics aren't as bad as they used to be... they're nearly as efficient as manuals are. Manuals still have vehicle control and longevity in their favor though.
Old 01-27-2009, 07:50 PM   #17 (permalink)
KiaRio ,
Welcome from me as well.
Enjoy your stay.
Cheers , Pete.
Old 01-28-2009, 12:40 PM   #18 (permalink)
Here's a nice demonstration of the Z*N/P concept.
(Starting around 5:00)
Old 01-28-2009, 06:45 PM   #19 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Very nice shots of internal parts in motion.
Coast long and prosper.
Old 01-28-2009, 09:52 PM   #20 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
If that's the case, idling has to be murder! Especially on cold starts...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Glides like a Brick Wall (Jeep Cherokee, GMC Pick-up) DonEaston Aerodynamics 22 10-26-2008 04:17 PM
New York mechanic Andyman Introductions 6 05-13-2008 12:02 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
