Old 10-26-2011, 07:00 AM   #131 (permalink)
Again. Why ball bearings in the wheel of the car under high presure of weight and sudden hits to pot holes do not require grease change whereas engines need oil change.
I simply dont believe the oil sellers that we should change the oil so often. Maybe once every 1 milion miles would be true. What matters in the life of an engine is the way of driving. You can change the oil every 1000 miles but if you drive the car reclessly your engine will be destroyed.
Old 10-26-2011, 09:58 AM   #132 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Because (most) engines use what are called "plain" bearings, which rely on a very thin film of oil between two surfaces to allow the parts to slide past each other. This requires a very high quality of oil and periodic changes to maintain that quality. If the film of oil isn't maintained, the two parts will come into contact with each other and wear will result.
Wheels use ball or roller bearings in which two metal surfaces contact each other (one part rolls along the other, like a wheel rolling down a hill) and require far less lubrication to keep them working properly.
Old 10-26-2011, 10:05 AM   #133 (permalink)
Patrick's Avatar
The vehicle manufacturers set the oil change intervals, not the oil sellers. In fact, many oil sellers are trying to sell products by advertising longer oil change intervals than the vehicle manufacturers recommend.
Old 10-26-2011, 10:33 AM   #134 (permalink)
Patric; are you telling me that there are no ball bearing where the arrow is pointing on the crankshaft?
Check the picture below.
I know there are ball bearings at both sides of the crankshaft as well?
Vehicle manufacturers and oil producers/sellers are one, they just have different names according to me.
Name:	VW passat crancshaft.jpg
Old 10-26-2011, 12:07 PM   #135 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
There are NO ball bearings in the bottom end of an engine, and certainly not in the crankshaft and connecting rods.
Come on, do a little bit of thinking before you form your arguments. Oil analysis can be very informative, give it a try.
I'm not coasting, I'm shifting slowly.
Old 10-26-2011, 12:15 PM   #136 (permalink)
Patrick's Avatar
YES. What you are looking at in that picture is the surface of a PLAIN bearing. It must have oil lubrication.
EDIT: You might want to read this: http://en.wikipedia.org/wiki/Plain_bearing
Old 10-26-2011, 12:51 PM   #137 (permalink)
I thought crakshafts have ball bearings in there but i was wrong.
Which is stronger to heavier loads; the ball bearings or the plain bearings? which one will last longer?
Old 10-26-2011, 01:00 PM   #138 (permalink)
Patrick's Avatar
Read this: Plain bearing - Wikipedia, the free encyclopedia
and this: Rolling-element bearing - Wikipedia, the free encyclopedia
Old 10-26-2011, 05:14 PM   #139 (permalink)
I see men. I thought ball bearing are stronger but according to wikipedia the plain bearings carry high amounts of load. Maybe because of the bigger surface metal to metal contact will disperse more load onto the bigger area.
This increases my believe more and more that the oil should not be changed. Because plain bearings are stronger than ball bearings.
Old 10-26-2011, 05:58 PM   #140 (permalink)
UFO
UFO's Avatar
Pretty much sums up this issue.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Alberta Oil Sands Gone4 The Lounge 8 02-19-2008 07:58 PM
Book report: The Last Oil Shock by David Strahan AndrewJ The Lounge 0 01-16-2008 11:55 PM
