Old 03-14-2009, 02:32 PM   #31 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 Honda City iDSI EXi
90 day: 47.47 mpg (US)
Originally Posted by cfg83 View Post
bennelson -
Wow! I really really really really wish I had steelies. It's just more fun!
CarloSW2
Then trade them for steelies... You will be inundated with offers!
Old 03-15-2009, 04:50 AM   #32 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
hummingbird -
Mayyyyybe I'll do that on the next set of tires, . But they were scratched up by the first owner, and me thinks that Saturn S-Series alloys aren't on anybody's most wanted list. In the meantime I think I will treat each wheel as an experiment until I find a solution that works for me.
CarloSW2
American Solar Energy Society
Old 03-15-2009, 11:50 AM   #33 (permalink)
Driving the TurboWeasel
Here are pictures of my efforts. Cheap Wal-Mart special wheel covers and $5 of vinyl sheet. Total cost: $20.
The OEM covers had fallen off. These look better than steelies, and do not have drag-inducing holes in them.
2012 Chevrolet Cruze Eco 6MT
Old 03-15-2009, 01:55 PM   #34 (permalink)
If they are loose enough to flap, they're probably hurting.
Old 03-15-2009, 02:38 PM   #35 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
99LeCouch -
I have to agree with Frank. Without knowing for sure, they don't look "tight enough" in the picture. If I had those wheel covers, I might try black duct tape on the back. Because the tape would be facing out, it would gather dust over time, but I think it would still look stealthy-OEM. Maybe I would even throw some fine grain dust at it to "coat" the tape ahead of time, or cut some cheap black kiddie arts and crafts foam sheet to stick onto the tape.
CarloSW2
Old 03-15-2009, 04:20 PM   #36 (permalink)
They have been wrinkly since I put them on there, and have not changed in 1000+ miles. Likely they're not flapping. The vinyl has hardened up considerably being exposed to the elements on a constant basis. The wrinkles are both being rushed in making them and installer error.
I will re-do them one of these days now that I have some good adhesive, as they're currently frictioned on. The goal is to get the vinyl flush with the wheel cover without wrinkles for a cleaner appearance.
Old 03-15-2009, 07:01 PM   #37 (permalink)
my first gmc's Avatar
Sierra - '96 GMC Sierra
90 day: 20.89 mpg (US)
White Lightning - '10 Mitsubishi Lancer GTS
90 day: 27.18 mpg (US)
you could use some sort of adhesive on the back(wonder if pvc glue would work), then hit it a heat gun to get any wrinkles out.
Old 03-15-2009, 09:43 PM   #38 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
99LeCouch -
Ok. Sometimes pictures don't tell the whole story. 1000 miles is a lot. Appearances can be deceiving. They are your "version 1.0".
CarloSW2
Old 03-15-2009, 09:56 PM   #39 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
They have that "I was too lazy to take em out of the plastic" look
blow drier, that should shrink the plastic a bit tighter..
Old 03-15-2009, 10:19 PM   #40 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Yeah, shrink wrap, like what's used for Window Insulation Kits, might actually look really nice!
Any just so you guys know, my hub caps are just screwed to "snap-on" plastic rings that pop on to my tires' steel rims.
The trucks rims were not modified/mangled etc. in any way.
Real easy to pop on and off, put on a different vehicle, check the air pressure, etc.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
wheel covers: corugated plastic or taped hubcaps? modmonster Aerodynamics 4 02-08-2009 07:54 PM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
