Old 08-20-2008, 09:13 PM   #21 (permalink)
Daily Driver - '01 Ford Explorer Sport
90 day: 18.12 mpg (US)
Send a message via Yahoo to Tony Raine
i am insanely jealous.......
My Intro
Old 08-21-2008, 06:54 AM   #22 (permalink)
Certified Freak
Greenblazer's Avatar
Greenblazer's Taco - '07 Toyota Tacoma PreRunner Double Cab SR5 V6 4.0Liter
90 day: 24.54 mpg (US)
Great scott Marty do you know what this means?
Cool Car! I would want to Hollywood it up and make it into a BTTF replica. I have heard about people swapping in other more readily availiable engines, and you might want to consider thinking that over before going with the stock one. Parts are probably cheaper on a common GM motor than the stock one.
Later,
Allan Greenblazer
Old 08-21-2008, 11:55 AM   #23 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I thought about this as well. If you're going for "show-quality", of course stock gets bonus points.
But the PRV engine was noted to be slow for 1980's standards. Is the concern finding swap parts for another plant (plus the ECU stuff)? Is a forced induction a consideration?
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 08-21-2008, 01:59 PM   #24 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
Making brackets is not difficult. I'd replace your gas struts with pnumatic rams. Then when you open the doors it will SOUND futuristic!
Old 08-21-2008, 02:04 PM   #25 (permalink)
TheDon's Avatar
Pepper - '87 Mercedes Benz 300D
90 day: 30.42 mpg (US)
I would never make a delorean a BTTF car, it ruins a perfect car in short order, plus you can't drive it anywhere at all.
I'm sticking with the PRV because its simple to install, readily available(I can get parts for it from a Volvo Dealership or online vendors), and it works.
KISS
The torsion bar stays, its proven and works.
The Bricklin SV1 used pneumatics and when they failed(which was often) the doors were so heavy the occupants would be trapped in the car. The Delorean door is around 80 lbs with glass and electronics in it.
Old 08-21-2008, 02:09 PM   #26 (permalink)
So why didn't you just buy the torsion bar from the previous owner with the car? You COULD build a reliable pnumatic system instead of a p.o.s. that can't lift a door reliably. If pnumatics can be used in transport trailer suspension reliably, then it can be used to lift a door reliably. Probably cheaper than the 1500-2k for a torsion bar.
Old 08-21-2008, 03:11 PM   #27 (permalink)
TheDon's Avatar
the I blew my savings on the car and the torsion bar was at $900 last I checked. They can be had for less than $1500-2k, thats just what the last one went for.
I know these cars inside and out, Like I've said, its proven and its simple.
Old 08-21-2008, 03:13 PM   #28 (permalink)
900 is a more reasonable comparison with the cost of pnumatics, i suppose. I still think it would increase the cool factor... maybe a future mod once the car is sorted... you could get the money back reselling your two t-bars.
What does that beast weigh?
Old 08-22-2008, 12:49 PM   #29 (permalink)
TheDon's Avatar
2800 lbs with fuel
Torsion bars stay, anything else, regardless of compelxity and quality lower the value of the car and also add in difficulties for future owners. stick to the K.I.S.S method and everything will work.
I've got the rear deck Louvers in my bedroom as well as the engine cover.
The Delorean will not be aeromoded at all....It will get an eibach lowering suspension for all 4 corners though. The underbody is already pretty clean since everything runs through the center back bone of the frame.
I am very excited that its coming home tomorrow. It feels like christmas.
Old 08-22-2008, 12:53 PM   #30 (permalink)
wow, i figured it would be a heavier car. I suppose that is a BIT beefy for a 2-seater "sports" car. Congrats on a cool cult classic car.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
a 50cc or electric mini car project? ebacherville Alternative Transportation 108 06-07-2022 01:32 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 01:21 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
