Originally Posted by Joe1234
The only Honda that is supposed to to get better fuel economy than the VX (according to the EPA) is the insight and some special version of the ever-so-ugly CRX. The insight costs way too much to be worth it and the CRX is just too damn ugly. that leaves the VX as the best option IMO. Is there another, more fuel efficient Honda that I'm forgetting?
I realize the OP has bought another car and this information no longer matters to them but since I am dealing with this exact situation I thought I would add some thoughts to an already good thread.
First of all I am building one of those ever-so-ugly CRX's as we speak. Ok it isn't the best looking car in the world but I think I have driven worse and if I can get 50-60-70 mpg I can live with it. LOL.
I used to work at Summit Racing for several year some time ago so I have a little bit of training or insight to what works and what doesn't work and why in the performance arena. I currently own a mid 9 second 140 mph (1/4 mile) V6 Buick. I certainly don't claim to know everything but have learned a few things in the 35 years I have been playing with cars.
My car is a 90 CRX Si that I am have an HF drive train in and one big concern I have is the exhaust. My car too was mutilated in all directions by some 16 year old. I have 3 of the HF or VX manifolds on hand but don't have a good converter which would improve heating of the 02 sensor and other factors as engineered.
Currently on the car is a set of these junk 4-2-1 headers with the O2 in one cylinder pipe. I don't have the exact diameter of the tubes but something larger than 1 inch and a primary length of about 10 inches. This header is much better suited to a 7000 rpm 200 HP engine than my 62 HP @ 3000 rpm engine HF engine.
They will make more overall HP gain at 7000 RPM up than stock manifold but that comes at the expense of a lot of torque at lower RPM which is what you need with the final drive in HF 2.95 or VX 3.25. I think there are gains to be made over the stock manifold with a small diameter, long primary tube header, but the stock would be a much better choice than these ebay crap.
I believe the large tube header will hurt fuel mileage because of the reduction in torque and will require a heavier foot to get up to and maintain speed at 2000 rpm. The only possible benefit I could see is if the wider throttle position reducing vacuum drag could possibly offset this but I find that highly unlikely but open minded.
I plan on removing the header from mine once I get some of the other bugs worked out of my build. Once I get the car running to my satisfaction I plan to build a set of small tube headers to replace them unless I decide to turbocharge it.
Just my thoughts on the subject.
Dave
