09-12-2024, 12:59 PM
#1651 (permalink)
Originally Posted by aerohead
4) I'm not looking at # 1617 until I have a 'reason' to look at it.
I'm not buying a TV until I have a 'reason' to look at it.
You're showing values for the lower-48, not the 'world.'
It was conspicuously labeled as 'Contiguous U. S. Maximum Temperature'. What's your point?
..Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster
..Make the best use of what is in your power, and take the rest as it happens. -- Epictetus
09-12-2024, 02:25 PM
#1652 (permalink)
* DNA mutations which produced caucasians, allowed white people to absorb enough sunlight for Vitamin D production ( teeth & bones ) in northern regions where the local diet may not provide for it, and sunshine was weak, compared to Africa.
It appears that vitamin D production is so vital that trading off UV protection for increasing vitamin production occurs whenever sufficient avoidance of UV light can be achieved. As the world increasingly has access to sufficient shelter and UV protection, biological adaptation will spend less resources on creation of UV protection.
* Photosynthesis 'STOPS' @ 104-F. World food production is in decline, amid an ever-increasing human population.
There's only evidence for the exact opposite of this.
- Historically the calories per capita have increased over time
- Humans construct "greenhouses" because it's insufficiently warm for plant growth
- The earth has increasingly greened both from having a higher CO2 concentration (plant food) and greater warmth (supports photosynthesis)
- Photosynthesis doesn't occur below freezing
- The optimal temperature for photosynthesis increases as the concentration of CO2 increases
" Low Temperature
Enzymes are protein molecules used by living organisms to carry out biochemical reactions. The proteins are folded into a very particular shape, and this allows them to bind efficiently to the molecules of interest. At low temperatures, between 32 and 50 degrees Fahrenheit – 0 and 10 degrees Celsius – the enzymes that carry out photosynthesis do not work efficiently, and this decreases the photosynthetic rate. This leads to a decrease in glucose production and will result in stunted growth.
Medium Temperatures
At medium temperatures, between 50 and 68 degrees Fahrenheit, or 10 and 20 degrees Celsius, the photosynthetic enzymes work at their optimum levels, so photosynthesis rates gauge high.
High Temperatures
At temperatures above 68 degrees Fahrenheit, or 20 degrees Celsius, the rate of photosynthesis decreases because the enzymes do not work as efficiently at this temperature. This is despite the increase of carbon dioxide diffusion into leaves. At a temperature above 104 degrees Fahrenheit – 40 degrees Celsius – the enzymes that carry out photosynthesis lose their shape and functionality, and the photosynthetic rate declines rapidly."
The global average temperature is 55 degrees, at the lower end of optimal growing temperature.
https://www.encyclopedie-environneme...hotosynthesis/
09-12-2024, 07:07 PM
#1653 (permalink)
You've been posting well-researched and formatted posts lately.
Re: the out of Africa theory, this video contends that all non-African humans are evolved Neanderthals.
Geneticist's Jaw-Dropping Discovery About Neanderthal Ancestry! (Warning: contains hot Neanderthal wimmins)
0:00 in a controversial new interview Harvard
0:02 University geneticist David Reich stated
0:05 that all non-africans are essentially
0:07 evolved
0:08 neanderthals furthermore he makes the
0:11 case that rather than only 2 or 3% of
0:13 our DNA coming from neanderthals
0:16 Europeans are actually up to 20%
0:18 Neanderthal this is because Neanderthal
0:20 DNA was removed from our genomes due to
0:24 Natural Selection over the last 50,000
0:26 years that actually the proportion of
0:28 non-africans ancestors who are
0:30 Neanderthals is not 2% which is the
0:32 proportion of their DNA in our um in our
0:36 in our genomes today if you're
0:37 non-african person it's more like 10 or
0:39 20% of your ancestors are Neanderthals
0:42 so you know if you want to make a strong
0:44 arguments you might argue that
0:45 non-africans today are
0:47 Neanderthals
When you compare African mud huts to the cathedrals it makes logical sense.
09-14-2024, 10:15 AM
#1654 (permalink)
' point'
You have presented regional temperature observations as supporting evidence for the notion of a 'fallacy' ( scam ) of 'climate change.'
'Climate change' is a 'global' phenomena, which is 'clearly' supported by 'global' temperature scatter-plots' which have been 'smoothed' utilizing statistical methods. Exactly as Albert Gore Jr. presented in his 'Inconvenient Truth' hockey-stick.
09-14-2024, 10:22 AM
#1655 (permalink)
' only '
Originally Posted by Piotrsko
Maybe your pbs does, mine only does DW and headline part of BBC and only at non prime hours.
With PBS' 'PASSPORT', you can stream everything from PBS.
09-14-2024, 10:54 AM
#1656 (permalink)
' evidence'
" Low Temperature
Medium Temperatures
High Temperatures
1) The UN data on 'available' calories per capita has nothing to do with crop yields. It has to do with making available, the logistics which enable food to be delivered to those at risk of starvation, like today in Gaza, Sudan, 'Texas', etc..
2) 'Calories' have nothing to do with 'nutrition' either.
3) Your own data clearly mentions decreased photosynthesis as a function of outdoor temperature, and 104-F clearly stands out in that data.
4) That data completely misses the point that, beyond 104F, the 'stomata' of the plant's leaves 'close' completely, arresting gas exchange, to and from the atmosphere; in and out of the plant, as a 'survival' mechanism.
5) Increased CO2 does not necessarily increase plant growth.
6) Photosynthesis occurs blow freezing underneath polar sea ice, beginning the entire marine food web, which is collapsing due to global warming.
7) According to the Rhodium Group, global food production is in decline, as of April 22, 2024 reporting on PBS ( this info was 'purchased' from Rhodium, and is not freely available ).
8) Earth's global mean average temperatures, as of 1900, was 56.58F.
9) As of 2006, Earth's global mean average temp. was 57.99 F.
10) A couple months ago, Earth hit 60.18F ( the IPCC's 2C target the scientists hoped we'd never reach! )
Your data trails off as of 2013. A 'lot' has happened on Earth since 2013. That's 'WHY' there's so much concern about our 'NON-LINEAR' climate change.
09-14-2024, 11:01 AM
#1657 (permalink)
' mud huts '
When you compare African termite mounds to African mud huts, it also makes logical sense.
African, Congoese pygmy fece-coated huts also.
10-03-2024, 10:28 AM
#1658 (permalink)
RIP for two neighbors?
Two of my neighbors spend winters in their family home, in the Smoky Mountains of North Carolina.
For those with television, you may be aware that a great deal of Western North Carolina is now 'gone', courtesy of Hurricane Helene's historic rainfall.
Cell towers are down. Power is off, impacting over a million customers, six days after landfall. There's no drinking water. 300 roads have been destroyed. Bridges washed away. Mud slides. Historic river cresting. Homes and businesses washed away. 193-deaths as of this morning. No place to land helicopters. No way to get trucks in. Saturated soil, plus clear skies = fog, preventing aircraft to land in areas where they might. 1,000 active-duty ARMY soldiers have been sent in to assist local, county, state, and federal 1st responders in search & recovery.
My neighbors live in the mountains above Asheville. We can't call them. They can't call out. We have no idea of whether they survived or not. All thanks to the historic water temperatures in the Gulf of Mexico.
Some towns in this region have existed since before the American Revolution. They've never experienced anything like this in recorded history.
Some Americans moved to this area, thinking it was immune from the effects of climate change. A fatal decision.
11-09-2024, 11:28 AM
#1659 (permalink)
2024 certain to be warmest on record
The Copernicus Climate Change Service is making the call................. https://climate.copernicus.eu/copern...20on%20record.
11-09-2024, 02:51 PM
#1660 (permalink)
How as your neighbors doing?
politicalbrambles.blogspot.com/2010/05/medieval-warm-period-indeed-much-warmer.html
Above average for the 20th Century. Any idea what that gray dip is? Why is the Medieval Optimum considered optimal?
