11-26-2020, 09:18 PM
#61 (permalink)
That's an old one.
The main stream scientists will say he is crazy, dangerous and no one should listen to him.
Main stream science ignored the observations and stuck with a theory that makes everything else work. Kind of like they did with global warming.
11-27-2020, 12:40 AM
#62 (permalink)
12-01-2020, 07:35 PM
#63 (permalink)
First x class solar flare of solar cycle 25.
It was pointed at least 90 degrees away from Earth and sent the x-ray Flux at earth well into the m class range.
Mars took a kill shot, if we had a manned mission there now, it wouldn't be for much longer.
12-01-2020, 10:23 PM
#64 (permalink)
Good thing we aren't 'shields down'? Right?
Those cavities inside Phobos are probably safe.
03-05-2021, 09:09 PM
#65 (permalink)
General relatively wrong, how and why at 6:14
https://youtu.be/_A7VFVwAA5U
03-05-2021, 11:54 PM
#66 (permalink)
9:34 Lateral waves!
This is from three days ago:
This is a nano-structured material that I think could hot-rod those interstellar light sails. But what I found interesting is at 1:50.
If they can levitate mice with diamagnetic levitation, they would need a magnetic field similar to being in an MRI machine. So it's good that that is benign.
But it also means that if your space ship has a magnetic floor and ceiling you could be reverse-levitated down to the floor at one G. Thus Artificial Gravity.
03-06-2021, 10:26 AM
#67 (permalink)
Where do you get that levitation power supplied from? Last I saw, MRI units are used to having dedicated high power circuits to generate they magnetic fields. One thing to generate a 3ft diameter field, another to generate an 8 ft diameter field
03-06-2021, 01:22 PM
#68 (permalink)
Well, if it's an interstellar starship, just put a little propeller on the front.
03-08-2021, 10:03 AM
#69 (permalink)
And fins on the back to keep it from turning due to prop torque?
04-01-2021, 10:38 AM
#70 (permalink)
Did you see the latest weird thing, Uranus is for lack of a better term flaring.
