Well done I see more progress.
The rotating mass reductions you have pursued add up to ~60#, I'd venture to guess equates to ~500-1000# of static weight reduction
The 04.5-07 pistons have some special design for emissions
Non EGR CR Cummins duse not exist.
I found this out when researching parts for an 05 medium duty Cummins with a misbehaving EGR valve the wealth of information that is the internet could only tell me I was not seeing what was in front of me and EGR hit the Dodge/light duity in 04 the physical valve didn't show up until the 08.
Re cam the motor is the only way to remove the non cooled exhaust gas non-recirculating system. By closeing the exhaust valve early they were able to trap spent hot exhaust in the cylinder displaces fresh air on intake stroke making a valveless EGR
, I can pull 6th @35 mph running ~900 rpms. never a complaint unless the hill is too steep
How is the 64mm(?s364?) Spooling ,at the extreem low rpms?on grades(5-9%) my 91 with an hx35w12 with a Quick Spool Valve sends in a written complaint using smoke signals running less than 1263 RPM( 55mph in 6th 2ndOD.61, 3.55rear 31.7"tire) due to insufficient air to make power from the fuel causing a rich condition and overly high egts for throttle position and speed 850-1050° ,by 1050@10psi is turning black, drop to 5th(.71 1470 ) 650-750°. Or run 66mph (6th.61 1516)and she spools 15-20psi depending on the grade.
IAT 70° ,that would be a wet dream -2to 20 above ambient with the itty bitty baby intercooler the first gen came with.worst seen so far this winter (its been mild) 11° air filter, 120° post compressor, 9°f IAT @70mph crossing the ID/MT Continental Divide pass
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg :
31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
