06-23-2008, 12:20 PM
#41 (permalink)
Veggiedynamics
man, If i could make a enclosed 3 wheeler with these hub motor kits, that got me 30-40mph id so drive this to work..
How's the 48v setup working .. more speed? Power?
Now how har will it be to make a 3 wheeler.. thinking a Aptera on a light weight scale.. Id buy one of thoe velios or whatever there called, but there so spendy, i know i could fad one up for less.. may be a bit heaver however.
06-23-2008, 12:42 PM
#42 (permalink)
Bicycle Junky
You need to check the laws for your state because, as per Federal law, an electric assist bike can not go over 20mph, some states are a little higher, but in general 20mph is the limit, if it goes up to 30mph it needs to be licensed as a moped, above that it's a motorcycle.
06-23-2008, 01:03 PM
#43 (permalink)
Veggiedynamics
I'm fine with that i have a cycle license.. been debating a electric cycle but want a enclosed cabin so I can use it in the fall/ spring/winters..
My CRX is close to what i want but still to big and wasteful for commuting.. But i need to go 60 miles a day.. in all weather..
06-24-2008, 01:53 AM
#45 (permalink)
Veggiedynamics
Originally Posted by skyl4rk
[IMG]
how the heck did they get that slick canopy?
06-24-2008, 11:18 AM
#46 (permalink)
The company makes/sells them: http://blueskydsn.com/
They also make the BugE electric 3 wheeler: http://www.bugev.net/
07-07-2008, 11:09 AM
#47 (permalink)
Glad I found this thread.
Does anyone have an online source for the HUB MOTOR? I am looking for just the motor on a 26 inch rim. Nothing else. I can not seem to find anyone selling this. Most places want to sell you a kit for $300 to $500 or more (I was thinking $200 with shipping included).
I do not mind getting a brushed motor. Want to use it as an assist motor so it will be wired with a spring operated switch (dead man switch) direct to the battery. My thoughts are to use this when I get tired of my commute (20 miles one way) to get home or up the hills. Eventually I will experiment with controllers and other switch technology.
07-07-2008, 11:12 AM
#48 (permalink)
Originally Posted by Lazarus
Looks like the batteries may be starting to fade. I have not noticed any performance or range difference yet but, after complete charge, 12 hours later, the pack voltage is reading 39.8v instead of the normal 40.v.
Lazurus - I know this is an old message, but did you look at Litium-Ion Iron (Ferrus) technology? This seems to be the best battery technology as it can last for 1000s of cycles of charging.
07-07-2008, 05:55 PM
#50 (permalink)
Coasting Down the Peak
