Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 06-23-2008, 12:20 PM   #41 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
man, If i could make a enclosed 3 wheeler with these hub motor kits, that got me 30-40mph id so drive this to work..
How's the 48v setup working .. more speed? Power?
Now how har will it be to make a 3 wheeler.. thinking a Aptera on a light weight scale.. Id buy one of thoe velios or whatever there called, but there so spendy, i know i could fad one up for less.. may be a bit heaver however.
Old 06-23-2008, 12:42 PM   #42 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
You need to check the laws for your state because, as per Federal law, an electric assist bike can not go over 20mph, some states are a little higher, but in general 20mph is the limit, if it goes up to 30mph it needs to be licensed as a moped, above that it's a motorcycle.
Old 06-23-2008, 01:03 PM   #43 (permalink)
Veggiedynamics
I'm fine with that i have a cycle license.. been debating a electric cycle but want a enclosed cabin so I can use it in the fall/ spring/winters..
My CRX is close to what i want but still to big and wasteful for commuting.. But i need to go 60 miles a day.. in all weather..
Old 06-23-2008, 06:18 PM   #44 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
http://home.mindspring.com/~kb7mxu/trikes1.htm
http://www.merit.edu/~rjd/fairing_construction.html
Add a rear wheel hubmotor and a high capacity LiFePo battery, something like 48V 40aH.
For example the 48V RoadRunner here:
http://electricrider.com/crystalyte/index.htm
This might be a good source for a low cost battery:
http://visforvoltage.org/forum/2702-...k-ping-battery
But get more than 20aH, you might need to hypermile to get 60 miles range out of 40aH. I'm not sure it will do long range, high speed riding, but you should get close to 60 miles range at 20mph. Actually I should not pretend to guess range, ask someone on an electric bike forum who has done it, at endless-sphere or visforvoltage.
http://www.endless-sphere.com/forums/viewforum.php?f=3
http://visforvoltage.org/forums/elec...s-and-pedelecs
Make a coroplast fairing.
This software will let you design boat shapes made out of flat plywood panels and will spit out the panel cut out coordinates which you could then stitch together to make a boat. Guess what, turn a canoe upside down, build it out of coroplast and it will work as a fairing.
http://www.carlsondesign.com/#Fun_Shareware
I would build one if I had an extra $3000.
Nissan Versa Aeromods
Old 06-24-2008, 01:53 AM   #45 (permalink)
Veggiedynamics
Originally Posted by skyl4rk View Post
[IMG]
how the heck did they get that slick canopy?
Old 06-24-2008, 11:18 AM   #46 (permalink)
90 day: 51.82 mpg (US)
The company makes/sells them: http://blueskydsn.com/
They also make the BugE electric 3 wheeler: http://www.bugev.net/
Old 07-07-2008, 11:09 AM   #47 (permalink)
Glad I found this thread.
Does anyone have an online source for the HUB MOTOR? I am looking for just the motor on a 26 inch rim. Nothing else. I can not seem to find anyone selling this. Most places want to sell you a kit for $300 to $500 or more (I was thinking $200 with shipping included).
I do not mind getting a brushed motor. Want to use it as an assist motor so it will be wired with a spring operated switch (dead man switch) direct to the battery. My thoughts are to use this when I get tired of my commute (20 miles one way) to get home or up the hills. Eventually I will experiment with controllers and other switch technology.
Old 07-07-2008, 11:12 AM   #48 (permalink)
Originally Posted by Lazarus View Post
Looks like the batteries may be starting to fade. I have not noticed any performance or range difference yet but, after complete charge, 12 hours later, the pack voltage is reading 39.8v instead of the normal 40.v.
Lazurus - I know this is an old message, but did you look at Litium-Ion Iron (Ferrus) technology? This seems to be the best battery technology as it can last for 1000s of cycles of charging.
Old 07-07-2008, 03:34 PM   #49 (permalink)
Speaking of batteries, I just saw what's in the Ford Escape Hybrid. Sanyo built them a battery pack consisting of 250 'D' Cell NiMh's.
A Battery That Will Change the World of Cars | SANYO Here & There | SANYO Electric Co., Ltd. Global
Who would've guessed that's all it was?
Old 07-07-2008, 05:55 PM   #50 (permalink)
skyl4rk's Avatar
Crystalyte Hub Motors, Eon Lithium Batteries, Electric Bikes, Electric Scooters, Parts, Service
Summer FE options - Scooter, bike assist, etc friedlbug Alternative Transportation 16 02-20-2009 01:41 AM
Bike riding at night - pointers. AndrewJ Alternative Transportation 9 03-30-2008 02:24 AM
my new bike for putting around town igo Alternative Transportation 4 03-23-2008 07:28 AM
The Ultimate Commuter Bike NoCO2 Alternative Transportation 13 02-29-2008 12:45 PM
lack of Bike Racks (for parking/locking to) Lazarus The Lounge 4 01-16-2008 01:49 AM
