Old 11-26-2013, 02:28 AM   #231 (permalink)
Minty Fresh - '15 Chevrolet Cruze LT
90 day: 36.06 mpg (US)
BlueBunny - '15 Mitsubishi Mirage
90 day: 40.64 mpg (US)
I dont have a pic of the glasspack on my computer, but I'll get one tomorrow, maybe. It's muuuuch smaller than the massive stock one.
And the 56lbs off the driveline is solely from wheels. My current wheels are steel rims with 185mm wide tires. The rims appeared to be alloys until I weighed them..each rim and tire weigh 39lbs. So, I will be switching to the Honda VX rims (using spacers up front to fit the brake), to end with an average wheel weight of 25lbs.
Old 11-27-2013, 12:47 AM   #232 (permalink)
just a curious look into weights if money did not matter
Wheels only = Volk CE28N Forged 15x5.5 7.7lbs 3.49kgs
Wheels only = Civic VX Cast 13x5 9.7lbs 4.39kgs
Wheels only = Volk CE28N Forged 14x5.5 6.5lbs 2.94kgs
Wheels only = Volk TE37 Forged 13x5 7.4lbs 3.35kgs
Old 11-27-2013, 01:07 AM   #233 (permalink)
Other mods you might dabble in?
Maybe I missed something? Did you or are you going to dabble in underdrive pulleys or flywheel weight reduction?
I have not seen any data on these mods for fuel economy but it would be interesting.
& while I'm pondering on the key board...
I seem to remember as a kid when my buddies would race motor cycles if their engine needed a rebuild they would send their crank in to get lighted & knife-eged to reduce oil friction . i wonder if this would affect fuel economy in a good way?
Old 11-27-2013, 12:38 PM   #234 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
I will install a lightweight flywheel in 3-4 month and a alumunium not under drive cs pulley.
my idea about weight reduction is that it can only be good. but for % fe increase I dont know
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 11-27-2013, 12:56 PM   #235 (permalink)
Why not go with an underdrive pulley while you're at it?
Old 11-27-2013, 01:10 PM   #236 (permalink)
40-60-40 MPH P&G
because most of the time there is no belt on my pulley and in the case I reinstall my belt its only for the alt and I allways p&g so I need all the power from my alt
MPG=1 TIME=0
Old 11-30-2013, 03:46 PM   #237 (permalink)
40-60-40 MPH P&G
update on my water circulation when I use my block heater project.
after 3 hours the coolent temp is about 4-5c less but the car feel more warmed up and the temp does not drop when I start the car plus the temp rise more quickly
MPG=1 TIME=0
Old 12-04-2013, 05:15 PM   #238 (permalink)
Here is a picture of my glasspack. I threw it on there myself (as you can see) lol. I just welded the glasspack to the piece that can be unbolted, and bolted it right up. I used a redneck type hanger that gives the exhaust the ability to sway and bounce if it needs to. Easy 7 lb weight reduction, and it sounds nice
Old 12-04-2013, 08:35 PM   #239 (permalink)
Any audio clips? I have never heard a 4banger with a glass pack
Old 12-05-2013, 07:36 PM   #240 (permalink)
haha, nope. It sounds better than a typical "fart can" style muffler. These echos have a resonator and a muffler stock, so my setup has the stock resonator and the glasspack. Nice deep tone with no cracking or rasp
alt delete, belly pan, electric water pump, grill block, hypermiler, modding, toyota echo
