Old 08-02-2013, 10:48 PM   #221 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by echo-francis View Post
avg of 94.4 mpg
Yeow!
Old 08-03-2013, 10:24 AM   #222 (permalink)
Burning oil to move air.
ausiasmobil - '06 Seat Leon 1.9 TDI Reference
90 day: 40.22 mpg (US)
EcoTxec - '99 Skoda Octavia 1.9 TDI 110 cv Laurin & Klement
90 day: 52.85 mpg (US)
i would do it but when I commute I carry my computer tower with me
There are a lot of people with DIY cargo bikes in my city like this:
and there aree lot of places where bicycle is the ultimate conmuter cargo machine :
Anyway, your fuel consumption is a very good result with a petrol engine.
Sold:
The Following 2 Users Say Thank You to ausias For This Useful Post:
HyperMileQC (08-06-2013), mikeyjd (09-06-2013)
Old 09-12-2013, 08:34 PM   #223 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
update, I beated my previous tank of 81.68mpg with 88.37mpg. i did 1497.6km on 39.879liters. and there are still things that I can improve
I recently did amp consomation test on some of the Accessories. here are the results from the smallest draw to the largest
alt disconected battery at about 12.6v with no load
car off, 50MA
car ACC, 100MA
car off,all lights on expect headlights, 420MA (leds make the difference )
electric water pump in the 6V mode with the diodes, 530MA
electric water pump in the 6V mode, 890MA
car on, 1.04A
heater fan at 1, 2.86A
electric water pump in the 12V mode with the diodes, 3.08A
radiator fan, 3.43a
heater fan at 2, 4.01A
electric water pump in the 12V mode, 4.7A
heater fan 3, 7.03a
engine on idle about 1600rpm about, 7.5A
all lights on, 8.53A
only high beams, 9.4a
heater fan 4, 10.41A
rear defrost 11.75A
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
The Following 2 Users Say Thank You to echo-francis For This Useful Post:
HyperMileQC (09-13-2013), TexasCotton (11-04-2013)
Old 09-17-2013, 10:58 AM   #224 (permalink)
90 day: 51.82 mpg (US)
Congrats!!
Old 11-04-2013, 01:03 AM   #225 (permalink)
Black Beast - '02 VW Goff Estate S
Great thread guys. Much to read and much to learn...
The Following User Says Thank You to paulgato For This Useful Post:
HyperMileQC (11-04-2013)
Old 11-11-2013, 08:22 PM   #226 (permalink)
40-60-40 MPH P&G
update: my car is now (lead acid free) my new battery is a lifepo4 20ah battery in parallel with a 108farad 16v capacitor ( 6 650farad 2.7v capacitor in series) it weight about 12 lbs.
the capacitor are there for the cranking amps because my lifepo4 battery can't start the car alone but the capacitor alone can do it . another use of the capacitor will be when I have to reinstall my belt (I dont want to charge the lifeo4 battery with my alt).
I found 2 li ion drill batteries and I thought: how can I use the power of those batteries to go further without belt. the solution, use the electricity of those battery to power my electric water pump. I made a switch that chose the source of the ewp (main battery or drill battery)
the battery is made of 20 3.7v 1.4ah li ion battery (5 packs of 4 battery in series in parrallel) that give a 7ah 14.4v battery
MPG=1 TIME=0
The Following 3 Users Say Thank You to echo-francis For This Useful Post:
California98Civic (11-21-2013), HyperMileQC (11-12-2013), jeff88 (11-12-2013)
Old 11-21-2013, 05:28 PM   #227 (permalink)
40-60-40 MPH P&G
update: I decided to use my ewp to circulate the coolant when I use my block heater. I made a circuit that send a 12v output 1 minute every 15minute (my ewp controller begin with 30sec off 10 sec on... so 1 minute on= 10 sec on) the circuit take its power from a 12v power supply pluged in the timer where I plug my block heater
MPG=1 TIME=0
California98Civic (11-21-2013), HyperMileQC (11-24-2013)
Old 11-21-2013, 07:38 PM   #228 (permalink)
Cyborg ECU
Wow. Exceedingly smart.
echo-francis (11-21-2013)
Old 11-24-2013, 10:58 PM   #229 (permalink)
Minty Fresh - '15 Chevrolet Cruze LT
90 day: 36.06 mpg (US)
BlueBunny - '15 Mitsubishi Mirage
90 day: 40.64 mpg (US)
Im loving this thread, echofrancis. Gives me tons of ideas for my echo; Im shooting for 50mpg with simple mods. Thanks for documenting everything!
Old 11-25-2013, 09:44 AM   #230 (permalink)
40-60-40 MPH P&G
I just saw your garage and :
do you have a picture of your Jones Glasspack muffler
and how will you remove 56lb on the driveline ?
welcome on ecomodder
MPG=1 TIME=0
alt delete, belly pan, electric water pump, grill block, hypermiler, modding, toyota echo
